Wheel Alignment
- Thread starter Marky Boy
Worth getting to know him for servicing too.
GreigM
http://www.porscheclubgbforum.com/tm.asp?m=47103&mpage=1뫑
Motortune is fine and Peter is a fantastic mechanic, but chronically overworked and because of it a bit unreliable
John H
Top bloke!
JH
PS ... I'd avoid Star Performance, no doubt good, but likely to be very expensive.
Mark
ORIGINAL: kitchens
I phoned him today and have prov booked in my car as it has just had new tyres and wheels put on it so want to make sure it is spot on ,would take about 1 hr and the cost no more than £60 a bargain me think's .There are plenty of car showrooms in the area to while away an hour or two.
Not meaning to imply anything by this, but surprised he can do it in just 1 hour when you read posts like the 9th one on this
http://www.porscheclubgbforum.com/tm.asp?m=285963&mpage=1&key=񅴋
saying it took someone 12 hours to get it spot on (admittedly with rusty bolts to contend with and maybe a 964 is more difficult)
Lets us have a report when it's done.
There was a world of difference between my car in 3 states:
1) Before clutch change
2) immediately after clutch change (with engine out etc)
3) then again after the alignment was "fixed" when I complained about handling
But I'm not convinced (1) and (3) above are quite the same and I would not mind paying someone, who really knows what they are doing, to redo the whole thing from scratch now I know what a big difference a few spanner turns can make.
GreigM
John H
By comparison, Star Performance wanted a minimum of £200 before they would even look at it.
Nuff said
I can understand how these jobs can take longer than expected. There has been many a time i have worked on cars and 1 seized or snapped bolt takes hours to sort. I am planning, weather and significant other half permitting to get under the beast and make sure that all the bolts are able to move ok. Then at least if they are I have time to play with them, and god forbid snap any it can be replaced.
On another note I notice that on ebay you can pick up a full set of PU bushes for <£150. I'm actually considering this as the originals surely must be past their best. Anyone got any experience on this? Is it too harsh or should I stick to OEM parts??? The car is not used on the track, but i do only use it for weekends mostly on the back roads.
'Edited as I can't spel proper'
CLCM gets my vote too.
Cheers Al
