Where to get torque tube reconditioned?
If it takes them as long as it took my dad then thats a good deal for them :D. Although we only repaired the wear on the contact faces.
After 3 weeks at the menders, I finally picked up the car on Saturday. Have only had a short blast since, but the driving experience has been greatly improved.
The whole job became involved when after fitting the rebuilt torque tube, apparently the transmission noise/vibration was still evident. Luckily they had another box from a known car which they then had to swop over. Even more fortunate, they sold some parts out of my box, so the exchange cost of the box was only £150.
The full work included clutch kit(good idea as the one in their was 16 years old and of the 'doughnut' variety, clutch shaft and bearings, clutch fork repair,gear selector(it was this that's £100 odd not the fork repair), flywheel bolts, rear main oil seal. Whilst about it, I also had oil and filter change and new oil pressure switch to cure the flashing dash light.
Lastly, I had the KW's reset to softest as in all honesty, I'd always thought they were a bit too hard as they were for road only use. The improvement in ride is quite dramatic without compromising cornering ability(those 968 anti roll bars do seem to keep it really nice and flat through the twisty bits). Doesn't seem nearly as bad over broken surfaces now - it actually works like good suspension should rather than skipping over the surface as it felt before, no matter what tyre pressures I tried.
So all is good for a while at least and many thanks to the guys at RPM.
With the engine mounts done a couple months back, that takes this year's bills to £3k+ in 4 months, but even worse, it equates to about £8.50 per mile [:eek:]
