Which Alloy wheels fit direct?
- Thread starter skendrick
jez_anderson
jez_anderson
Basically you want the total of the Boxster wheel offset and the spacer to equal the offset of the D90. The offset will be the larger number cast into the rim by the valve stem on both types of wheel, the other being the width.
A5DSR
Can't decide what size spacer to fit. This place suggests 7mm, http://www.wheeldynamics.net/appguide.html
open to suggestions...
Daz.
ORIGINAL: Fen
They will fit a post '87 car, but they will look a bit narrow at the front unless you fit a shim type spacer.
Ben, if your car is pre-'87 (I think it might be?) then they won't fit yours without a 30mm spacer each corner.
Mines a 89 mate, so should fit shouldnt they without spacers right? though like one of the later posts maybe need some spacers for the front!
Neil Haughey
It's only the Bogster wheels that need spacers anyway, and I sort of feel the same way about them as 16" Cups. Something from a 911 will have a better offset and there are genuine Cups around for sale - 2's easier to find than 1's though.
sawood12
Neil Haughey
Well I quite like them, especially next to D90's which are plain aweful. True though that out of the bigger cup wheels the original cup 1 ones look best. Why do you say they are a con? They cost me no more then recon D90's and they give better cooling and ISTR where definitely lighter. For aftermarket wheels I really like the Azev's on a turbo/S2, if it wasn't for the fact that every bugger is copying the lambo wheel designs (like golf gti 18") I would have said one of those would look ideal on our cars. The biggest con is spending £2K on 18" and tyres that weigh a tonne and most likely make the car slower.ORIGINAL: Fen
I have to agree with Mik. I'll also add that in 18" I prefer the Cup 2, whereas in 17" it has to be the Cup 1 for me. I'm pretty sure 16" Cups are a con and really they are 13" rims - they look like it anyway.
