sawood12
ORIGINAL: 944 man
ORIGINAL: Hilux
Not entirely as this can be offset by the increase in (or regaining back) the mechanical advantage by using larger discs BUT at the disadvantage of increased unsprung weight.
Of course. My point is that increasing the rolling radius without increasing the size of the drake disc, reduces the braking effort felt.
It works opposite way - i.e. you have to increase braking force if you increase the wheel dia. Think about it this way. Braking is all about energy. The energy the brakes have to generate is the same irrespective of the size of the wheel relative to the size of the brake disk - it's all about the weight and speed of the car. All brakes do is to convert kinetic energy to friction (i.e. heat). The energy generated by the brakes is dependant on the area of the frictional surfaces (i.e. brake pad area), the force applied by the caliper (i.e. pedal pressure) and the speed of the brake disc surface travelling past the brake pad (i.e. wheel rpm).
Therefore if you increase your rolling radius of the road wheel whilst keeping the brake disc dia and brake pad area constant you slow the wheel RPM down for a given speed, therefore the brake disk surface is travelling past the pad more slowly therefore less frictional energy is being generated and your decellaration rate will be slower. So to compensate you need to press harder on the brake pedal to increase force applied to the brake pads.
So using the same principle as long as you keep the pad area the same and the road wheel rolling diameter the same then varying the disk size wont matter to the braking force applied.
