Hi, I have had a search through and come across head gasket issues, coolant getting in to cylinders and also high mileage engines needing a carbon clean but i'm just looking to see if anyone has had similar to what has been described to me by the owner (Haven't picked the car up yet but deposit has been put down) This is what he described the problem to be.
"it does smoke on the over run, but doesn't seem to get through much oil. If you rev much past 4 and a half thousand revs it burns a bit of oil too, but again, this has improved a lot with constant use, and I very rarely get past 4. It uses a little coolant, which I can't notice in the reservoir, but there a little white 'smoke' on start up on a cold day. I haven't had to top it up since I've had it though. Both these are sorted in a weekend with a light head refresh. It sits bang in the centre of the temp dial on the motorway (had a run to Tesco today, went to the one ten miles away for a little drive). For town driving these is a manual fan installed, which quickly pulls it down towards a quarter of the dial, even today when it's twenty degrees outside. Oil pressure is very good, in fact it is better than my GT3! "
To me it doesn't sound too much like the HG as it's not losing any coolant.. (or marginally) and also temp sitting as normal and no loss of power etc could it just be full of carbon? Car is a 1984 Lux with 134k miles on
Adam
Adam
