GOOFY
Hi
Think I overrevved the engine today - couldn't help it, hood down, sun shining, had to give it a blast ! Don't think I hit the rev limiter, as I did not feel a sudden cut out, all I remember was the sound of the engine becoming turbine smooth and very high pitched with a fall off in acceleration before I snatched second gear.
I very very rarely rev the engine past 4000 rpm (Beetle owning habit!) . In fact I can count on my hand the times I have exceeded 5000 rpm in the last 2 years (5k miles). I commute in London and I have hit the rev limiter once since owning the car ! I have read "Honest John's" column in the Telegraph in which he says "one should "stretch" the engine occasionally - at least once a month to maintain the top end smoothness". Does this apply to Boxsters ? Mine has done only 25k miles and I don't want it becoming lethargic at high revs, nor do I want it to get RMS/ crank bearing damage by hitting the rev limiter to often .[
Boxster 2.5, True flow, By pass Exhaust.
