ORIGINAL: sawood12
Charles, there are two reasons for my experiment with the new wipers. Firstly asthetic - i thought the stock 944 wipers look dated and mine were looking a bit tatty and in need of a refresh. I personally think the modern wipers look better as they are more low profile and windscreen hugging.
Secondly I was dissatisfied with the performance of the stock wipers, especially at speed. I noticed that the wipers have a tendancy to lift at speed which I think is due to the fact the wiper arm comes over the top of the wiper blades and the airflow off the bonnet gets under the arm and tries to lift the arm which reduces the pressure of the blade on the windscreen at motorway speeds. Rainex improved the situation a bit but I was still unsatisfied. I firstly tried the Ebay flat blades discussed on the other wiper blade topic thinking that the blades might be aerodynamically better than the standard ones and counteract the lifiting of the arm. This wasn't the case and they brought no real improvement. I personally think that the modern arms and blades will get around this problem due to the fact the arm is paralell to the blade rather than over the top of it therefore not in the airflow as much. I chose the Lupo wipers as they seem to be the best fit in terms of the length of the arm and the fact there is an almost 45 degree kink in the arm at the root, which you need on the 944 for the arm to clear the bonnet.
The arms are off the VW Lupo GTi (the non GTi models use conventional wipers) and for the 944 you would need two drivers side arms as the Lupo passenger side arm is longer and a different shape and use a longer blade. The arms are about half an inch or so longer than the 944 but use the same length blade (19"). This means the sweep of the wiper blades is translated to the left by about half an inch but there is plenty of clearace.
Currently I have a Lupo wiper on the passenger side and it does work much better than the standard arm/blade, probably as much due to the much stronger spring as the aerodynamic properties, but i've now encounterd this slight scraping problem. Not decided if it is a problem in terms of damaging the windscreen or not as the spring is only just ever-so lightly glancing the glass rather than gouging into it and only at motorway speeds, so have holded off completing the mod and buying an arm for the drivers side as well until I decide what to do or if I spot the wipers off another modern car that might be a closer fit.
