Wishbones!
- Thread starter dann944
Steel wishbones on early cars are cheap, alloy wishbones on later cars expensive.
woodymcnab
but could not get a mechanic to do the work, not even my local porsche specialist.
he said the repair kits are no good and have a high rate of failure after a short time span.
best bet would either to buy a brand new one and swallow the cost or go to a porsche breaker and get a good second hand one. make sure the bushes are ok though or they will cost you another 45 quid (ish)
the second hand one will cost anywhere from £50 to £150 depending on the breaker.
hope this helps
woodymcnab
944 man
ChasR
One known specialist on here (south of the country compared to me) said to me in his opinion there are two options when it comes to balljoints (on later cars). You can rebuild them yourself, but it depends on the kit. He said that he'd only trust the kits from www.rennbay.com (I know some people here have used the geometry correcting balljoints on lowered cars). The other option he suggested were the Hartech arms which are built using metal top parts as opposed to plastic, hence less likely to fail (I think the the design is more akin to the 968 wishbone).
Regarding the bushes, if you are on 17" wheels, it is said to be a good idea to go to 968 rear castor mounts.
Tam Lin
In my case it sounded at first like a loose anti-roll bar, i.e. road bumps/sleeping policemen would cause a knock from the affected corner. Any clunks from the front suspension are worth investigating.ORIGINAL: gavinm
what are the symptoms for a driver if these are knackered? how does the car feel?
cheers
Gavin
