Gazza3501
Part 1
Like many, I’m not working during this current lockdown phase so I thought I would use my time to rectify a couple of issues with my Boxster and share the info & photos with like-minded folk.
I have a Tiptronic 2.7L Boxster registered in December 2006 with the usual weep under the gearbox and severely corroded exhaust nuts/bolts and broken clamps. I also have a MIL (Malfunction Indicator Light) illuminated on the dash which my Durametric tells me is an exhaust o2 (Lambda) sensor issue. I have not been able to remove said sensors as they are seized tight. I decided to whip the engine & transmission out (as you do) and sort the issues.
Many people say you should leave the exhaust manifold bolts well alone—and they are correct!! They are poor quality and often snap. If this happens you can find yourself in a whole world of sh*te! I did this very same job on my last car, a 997C2S and luckily all bolts came out ok and I installed new gaskets and bolts just for peace of mind. On this Boxster I needed to remove the entire exhaust but in two halves --left & right. After cutting the bracket that joins the two halves I proceeded to snap 5 manifold mounting bolts on one side and luckily only one on the other. I tried different methods including heat to no avail. It just goes to show how different patterns of use and storage conditions can affect components. My 997 being eighteen months or so older but similar (mid 50k) mileage was in much better condition with no corrosion anywhere.
I thought 911’s were awkward to work on but the Boxster is in a different league. I purchased my first Porsche in 2010 and I immediately knew I would have to have a means of comfortably accessing the underside of the car so I invested in a portable car lift (pictured) called
EZ Carlift. It raises the car just over two feet which is great for most types of work especially dropping an engine. I have used this lift on everything from my sons old MX5 to a Mondeo estate. If you do a lot of your own mechanicing as I do then I highly recommend a lift like this they are so much better than axle stands (although considerably more expensive of course) especially when you get to a certain age and don't want to struggle.
Accessing the engine:
One reason for engine removal:
another reason:
I will post more info & pics as things progress and when time permits
![d93wrDT.jpg](https://i.imgur.com/d93wrDT.jpg)
![PuE2SSsm.jpg](https://i.imgur.com/PuE2SSsm.jpg)
![D63ijvY.jpg](https://i.imgur.com/D63ijvY.jpg)
![XPpFTdM.jpg](https://i.imgur.com/XPpFTdM.jpg)
![nvpqCCjb.jpg](https://i.imgur.com/nvpqCCjb.jpg)
![O7XEXzsb.jpg](https://i.imgur.com/O7XEXzsb.jpg)
![LBXyFCtb.jpg)](https://www.porscheclubgb.com/forum/[Imgur](https:/i.imgur.com/LBXyFCtb.jpg))
![LBXyFCtb.jpg](https://i.imgur.com/LBXyFCtb.jpg)
![YhToIGIb.jpg](https://i.imgur.com/YhToIGIb.jpg)
![PqK5ugC.jpg](https://i.imgur.com/PqK5ugC.jpg)
another reason:
![P8VpTu3.jpg](https://i.imgur.com/P8VpTu3.jpg)
![u1GFpA0.jpg](https://i.imgur.com/u1GFpA0.jpg)
![h5eGQyZ.jpg](https://i.imgur.com/h5eGQyZ.jpg)
