Dan944t
PSH said:Dan944t said:i’ve got a catch can on the front right behind the nearside front light, so it’s sort of in the way now i suppose, will have to move it else where if i want to pipe it somewhere there but not really sure where to put it
Hi Dan
I have my catch tank where the charcoal canister used to be, I have a large bore silicone hose which goes through the hole that the canister hose used to use, a bracket was made using the original canister mounting points to hold the can in place.
This is where it sits, I think we may have made a better bracket later, can't remember..
This picture helps to show where the hose runs, you can see it running along near the top of the bulkhead and into the wing.
H, the position that Dan has his air filter which as rightly been pointed out by Paul to not be in a good place is where that adaptor that I have will put it. This was back in the day where modifying 951's was relatively new, hell, back then we didn't use a 3 BAR FPR, we just squeezed the original a little to increase pressure. This was actually the direction given by many aftermarket parts suppliers 20+ years ago. IIRC instructions were given on LR's website, along with others.
Pete
hi Pete, thanks for that idea never thought if that area,..problem is i like it to be easily accessible , so will be putting my standard air box and K&N filter back on i think till i n afford a maf kit, so will leave where it is as i fabricated some brackets up and it’s nicely bolted in place for now. when i change AFM to maf kit i will think about where i will put it, even if i have to buy or custom make another can to fit maybe on the left near the power steeering bottle or something?
