1986 turbo front discs
- Thread starter James0
924Srr27l
The OE compounds and aftermarket makes like Textar, Delphi, Pagid, Brembo, Mintex, TRW, Febi, Sebro, Ate, Apec, etc will all have a low to mid temperature ranges
and hence will not stand up to heavy punishment on the road or trackdays, if they overheat , the Discs may bend & wharp.
Some of Brands above will also list pads with higher heat ranges, but then if the Brake discs are not heat treated they are even more likely to bend when subjected to pads that
can be taken to a higher temp but the discs can't handle this! (More wharping)
One Example here is TAROX, who list some track day /race orientated pads @ £194 (You can easily get discs and pads for this, but they will be cheap for a reason, so unless your driving your Porsche like Miss Daisy! there's a chance they will bend)
https://www.ebay.co.uk/it...811:g:gWwAAOSwBChbYDON
Their Discs unlike most have been heat treated for strength and hand finished to ensure the smoothest possible braking surface.
Tarox Sport Japan Brake Discs
https://www.ebay.co.uk/it...99a:g:5kYAAOSwW3dbaIJu
These and other higher end & race products the pads are designed to use cohesive friction to produce brake force. The brake pads transfer a thin layer of pad material on to the rotor surface known as the transfer layer. The braking force is achieved by continuously breaking the adhesive bonds between the brake pad and the transfer layer on the brake disc.
A problem can occur if this transfer layer is not laid evenly and consistently on the disc faces.
Inconsistencies in this transfer layer will cause uneven friction levels during braking. Over a reasonably short period of time these inconsistencies can progressively become more pronounced resulting in pedal pulsation, brake shudder and the steering wheel shaking. This problem usually occurs as a result of the brake pads not being initially bedded in correctly so as to lay a consistent transfer layer evenly onto the face of the rotor. Slotted and/or drilled rotors can be more susceptible to this problem due to the pad cleaning effect of the slots and/or drilled holes.
Do not choose a high performance pad if you do not drive the car aggressively otherwise the discs are likely to wharp especially when new and bedding in as
insufficient heat generated in the braking system the pads are prone to glazing if run too cold. If they glaze they will lack bite and feel and then overheat much quicker (Because you press the pedal harder) transferring the excessive heat into the discs which also may then overheat and bend.
R
scam75
Well-known member
Yeah, those are non M030 front pads which are same as rear pads for a turbo. Cheapest I can see M030 textar is £69.99 delivered from ECP using code FLASH50.blade7 said:Thanks, will check next time. But the 2nd listing says front and rear, same size?dlknight said:blade7 said:I fitted Textar pads on the front last time, can't remember where they came from, probably CP4LESS. The original price was silly, and even with a big discount they were still around £90 I think. They've never squealed though, unlike the previous pads that sounded like stuck pig under 10 mph.
Next time have a look on ebay I got some textar pads (M030 rear) for £22 -
https://www.ebay.co.uk/it...t-2087702/391887833148
These guys seem to have a lot of OE Porsche parts for great prices.
The front M030 pads are £35 (for Textar) -
https://www.ebay.co.uk/it...-2095302-/391887833104
And they were genuine parts in a Textar box with the Porsche label on the outside (plus the hologram sticker).
Blade - Are you using shims with yours?
Stuart
blade7
Well-known member
scam75 said:Yeah, those are non M030 front pads which are same as rear pads for a turbo. Cheapest I can see M030 textar is £69.99 delivered from ECP using code FLASH50.
Stuart
I checked the receipt, it was CP4LESS and 5 years ago, they were the cheapest seller for those pads I found. Re the shims, I reused what was already in there. I think they're called vibration dampers, with a bit of copper slip. The old pads had loads of life left, but the noise was terrible. I also notice the Pagid dics had a different part no. for left and right. They haven't warped in the last 10k.
scam75
Well-known member
Stuart
scam75
Well-known member
Confused now. Do all turbo s and 250bhp turbos and M030 cars not have the 304mm discs and larger front pads and calipers?
blade7
Well-known member
220 bhp turbos have smaller discs.scam75 said:Confused now. Do all turbo s and 250bhp turbos and M030 cars not have the 304mm discs and larger front pads and calipers?
blade7
Well-known member
Tony
Waylander
you see sets of hubs, spindles and calipers for upwards of 2K second hand,
they are all different to the normal 97mm Brembos as used on the turbo and 968,
i had to look in PET for someone with a bent M030 spindle for a 968, they are nearly £1800 each new.
If you wanted to do this with all new bits and they are available, it would cost close to 10 grand
Waylander
erm no not reallyscam75 said:Shouldn't have gave away my old calipers when I got a better set then should I? [&o]
calipers M030 with the dust caps not scraper seals, £1200 each, disks £160 each, Pads £209, Hubs £936 Ea, Knuckles £1500 each, plus all your bits and bobs, so 10k was a bit OTT, say 8K and your close
blade7
Well-known member
How much are the standard 250 bhp calipers and discs from Porsche though? I wonder how much difference the MO30 stuff makes on the road. I came close to buying a red Turbo S that had 993 TT brakes on the front, I think the drilled discs were quite expensive.Waylander said:calipers M030 with the dust caps not scraper seals, £1200 each, disks £160 each, Pads £209, Hubs £936 Ea, Knuckles £1500 each, plus all your bits and bobs, so 10k was a bit OTT, say 8K and your close
