Oli,
I’d agree with Dave that something’s amiss with your hill-hold function, particularly if as you say it’s not releasing smoothly. Thankfully my 987.2 has a proper handbrake and not an inaccessible push-button at knee height so I rarely make use of the facility and there’s no visual indicator that hill-hold is in operation. Have you checked that the parking brake is engaging and releasing fully by jacking each rear wheel clear of the ground? If one side is binding-up it will give you an idea where to look but if the parking brake is working correctly then it will indicate a problem with the hill-hold system which must include some sort of incline measuring sensor.
Just to add that in case you’re not aware of it, the parking brake is separate from the foot brake. The bell of the rear disc forms the drum of a leading and trailing shoe drum brake and it’s possible that some adjustment is necessary. On my 987.2 CS the adjustment is mechanical but it seems that on the 981 and most likely on your 718 the ‘air gap’ has to be set using a diagnostic tool, so I’m sure that the dealer will be doing this as a matter of course while they’re checking the hill-hold function when you take in the car later this month.
https://uk.autologic.com/news/checking-parking-brake-air-gap-on-porsche-981-models
Jeff
Jeff
