BIG DAY today for me and the Lola, morning at the rolling road, BHP Performance, very local to me which is nice for a change.
Strapped the car down on the rollers and warmed it up. First time Ben had seen the Clewett ignition system, but no probs, he just thought it strange...
Broke the engine in for 20 mins up and down the rpm in 2nd and 4th to load it all up and then set too setting the advance positions, tick over, 3000 and 8000 rpm, the latter somewhat academic!
Mid way through the engine died suddenly. Loss of power to the ECU, blown 7A fuse, so 10A fitted (max current draw is 10A)
Got going again and did a few runs and a few discussions and ran the engine to peak power.
At this point we hit 295.6 bhp @ 6776 rpm, 243.2 Lbft @5066 rpm.
(transmission losses are 35 bhp)
Engine sounded great, good oil pressure and 100 deg C.
Talked about where more could be gained, filters (oiled KN fitted) and maybe carb chokes (38mm in 50mm carbs)
We decided to leave it there, the curves are great, very smooth and it sounds like it could go much further.
I expected/hoped for a good 300/320, 100 bhp /litre would have been great.
Engine still tight, and we didn't want to push the timing further but did try on deg less and lost 5 bhp, so we could be very close.
Needed to add fuel at 6K so re-jetted the PMO's and that helped.
Very happy with this, smooth engine, lots of torque and no peaks or flats.
Quick little video here, try opening the sound up.
Sounded ballistic in the chamber!
https://youtu.be/Btr1ATBrrLc
