I've toyed with the idea several times Jeff, also fitting a Boxster drive train which is ;just; too wide to go in.
Plan B is cooking well so far:
Bin the Clewett ecu and change it for a DTA Ignition-Only unit, type T2i
Will be calling Alex at DTA tomorrow morning to see how the DTA ecu might interface with what I have.
The Clewett ecu is £650 total cost, maybe £700.
I have no faith they will replace my ecu. Might get a surprise, but doubt it.
In which case I need to move on and get this thing done.
DTA are 1 hour away from me, ecu made in England and £412
It may well be better to bite the bitter bullet and get back in control.
[h3]Product overview[/h3]
The T2i is the ideal choice for historic, carburetted engines. It has wideband lambda monitoring and logging to help tune and diagnose fuelling issues with carburettors. It has flat-shift for dog-engaged gearboxes and can run engines up to 12 cylinders with distributors or 4 cylinders with wasted spark. It even has launch control and boost control!
Does your mechanical fuel pump need replacing or upgrading? Not a problem, the T2i can safely control electronic fuel pumps so you can upgrade safe in the knowledge that if you have a smash and the engine stops, the pump will stop too.
T-Series engine control units are powered by an all-new, automotive specific, multi-core processor. They feature Bosch lambda controllers for maximum accuracy, multiple safety redundancies, high resolution map tables, fully configurable I/O and up to 32MB of logging at up to 500 Hz with compression algorithms for fast log downloads. The PC software has a user-friendly, responsive
design for better readability on high resolution monitors using high scaling (DPI). It features a full oscilloscope for crankshaft/camshaft signal analysis and allows firmware to be upgraded without special cables or separate software.
