944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
924Srr27l
PSH said:hmm.. you do realise that even taking the lightest production 951 and the heaviest, we are only talking 100kg difference, which is why I say in this scenario the difference is a moot point.
Eldavo : I don’t really see any 944T hitting much more than 180mph without big power and a different gearbox.
I agree on this.......
All this pub talk Pete:
- "I have driven well past 170mph (btw, that was with only 282 bhp) "
- "He has two 951's, one is modified for the track, more power than mine but on banked circuits, he has seen it log 200mph."
- "he said the '86' 951 is the best car that Porsche has ever built"
R
924Srr27l
vitesse said:Pull the other one,Roger-momentum doesn't propel a vehicle-but helps a vehicle sustain its speed all things being equal.
If your theory were to be true ,how come Colin Chapman didn't make his designs as heavy as possible.
Why are Single seater racing cars so light -why not race trucks ???????
Lotus Elise S1 1.8L 116bhp 750kg top speed 126mph (155bhp / per ton)
Vauxhall Vx220 2.2L 145bhp 945kg top speed 135mph (165bhp / per ton)
Porsche 944 T 2.5L 217bhp 1350kg top speed 152mph (160bhp / per ton)
The super light car's handle and accelerate very well, all 3 examples above have very similar power to weight ratios,
but the 2 lightweight Lotus chassis cars are down on the top speed figures, the heavier German 944 is 80% heavier
than the S1 Elise and hence this MASS allows it to have a higher top speed..
R
924Srr27l
PSH said:If you owned one, you would understand just how good they really are and I'll leave it at that...![]()
I did try really hard, and tested one (220 model) to buy from www.autographspecialistcarsltd.com/cars-for-sale
It didn't drive that nice and just didn't feel that quick but I've driven up from Milton keynes to Wakefield in my Daily
a Volvo T5 225bhp 2.3 estate and that did go well for a barge....
I drove another years later this time my daily was a 968 3.0 and again it just wasn't happening...
R
924Srr27l said:vitesse said:Pull the other one,Roger-momentum doesn't propel a vehicle-but helps a vehicle sustain its speed all things being equal.
R
You can't just go by weight here.. there are many other factors to consider, gearing by just one of them, btw... looks like you are using the US figures here for the 944T... UK figures for 86 are 220bhp and 1280 kg
924Srr27l said:PSH said:hmm.. you do realise that even taking the lightest production 951 and the heaviest, we are only talking 100kg difference, which is why I say in this scenario the difference is a moot point.
R
oh.. I guess that I should answer this one, I was just going to ignore it. I try to verify anything that I say, so:
the 174mph was logged by GPS and the car was still pulling/accelerating hard at the time, no possible speedo error.
The details about the guy with the two 951's and the 930 describing what he thinks is the best Porsche after owning 40+ Porsches was published in the 'Excellence' magazine 2019.
Was he partaking in 'pub talk' too? I think not.
More clarting about with wiring and then got all the coolant branches and connections on - I’ll be amazed if there isn’t at least one that needs a bit of a nip up when up to pressure I always forget just how many there are. Connected up the inlet tubing too and replaced the metal vacuum tree under the manifold with some silicon piping as I was only using the AOS to inlet pipe anyway.
One last coolant connection to go in and then the heater pipe too, inlet manifold, etc. next.
Will be a job for a few weeks time though as don’t want to introduce too many variables until it’s running and been for it‘s MOT.
I managed to finally snap the wire to the auxiliary pump thermostat today too, it’s been hanging on for dear life. Just about enough of a nub to solder onto them 4 layers of heatshrink to support it and hide my soldering sins!
Will patch the flying lead into the harness on Monday.
https://www.finjector.com/documents/550bedaf32fb6/Double_Fire_Coil_2x2_Datasheet_0221503407.pdf
I know racers using it in place of the Dizzy and they’re doing 45 minute races without failures. Let’s be honest, the Dizzy doesn’t really get that hot anyway. I’ll mount it on a plate that will act as a heat sink of sorts too.
