Ran like a bag of poo with a bad misfire and lugging under any load. One of the HT leads was showing open circuit so replaced that with one of the 20 others I have! Ran great then started bogging down and super-rich. Plugs out, cleaned them up, O2 wideband out and it was so caked in carbon it wouldn’t calibrate. Cleaned it up and recalibrated it, put everything back together and it still fired up but super rich still.
A bit more head scratching and I loaded up the old config file for the ECU, quickly changed the trigger settings for the TTV flywheel - the joys of a decent user interface and a Bluetooth connection between laptop and car. Fired up first time and ran smooth and sweet, quick sense check on the fuelling figures and then I backed it out into the yard and spent 15 mins breaking the camshaft lifters in - tweaked a few other things while I was at it, I now have an accurate oil temp sensor in the sump which displays on the laptop and the head unit as a digital gauge.
Only other issue is that in refitting the fans, the radiator had popped out of the fitting that holds it in place at the top and my nice red S-shaped silicon hose has now created some lovely pink dust where the fan has caught it. Will remove and inspect, replace if necessary.
After 10 mins of running, all the oil had burnt off the exhaust manifold and all was good in the world. Need to bleed the power steering and adjust the alternator belt tension, refit the top half of the belt cover and it’s off for MOT on Monday. Got an under-load break in procedure for the rings so if we take the scenic route to the MOT station then can maybe get that done on the way there and back
