944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
scam75
Well-known member
My car stands on its nose now with a lovely progressive pedal, and so far I haven't triggered the ABS, even in the wet. I know it works as it used to cut in regularly even with half-hearted wet braking. An almost inoperative front caliper however would explain that.....................
45 mins later and the only missing fluids from the car were V-Power, no lights on the dashboard for once either"
How satisfying that must be after all the drama. Brilliant result with more to come - after 46 pages of bloody minded determination. A great story.
TTM
Well-known member
Congrats for all the hard work, especially how you remained stoich with the recurring oil leaks. I can't wait to hear how you get on and excited to hear how much it will make once fully tuned.
Stuart - I was pretty much in the same mind frame as you about the bigger brakes especially as I did not want to increase unsprung weight but really the car has so much more power with that sort of engine that the bigger brakes become a necessity, and once you become accustomed to the power and drive the car at its natural pace they end up feeling not a lot more powerful than the M030's, at least with std pads.
Good point about the bias - I did fit the 928 GTS bias valve to increase power to the rear brakes, and the car feels just fine under heavy braking now.
Good news about the ABS, what are your impressions of the new uprated front brakes?
Hard to say really - will probably know once I get it on the track. When I did have to stamp on the anchors they bit well and were easy to modulate without locking up.
You are not going to leave us standing there, like all these other 16V turbo guys who keep boasting about massive performance yet won't provide a proper dyno sheet, are you?
You get the dyno print out at the end of the day. When I actually make it to the end of a dyno day then you’ll be the first to see it I promise!
Considered the 928 GTS bias valve too but holy moly they know how to charge for them - £££££££
scam75
Well-known member
Cheers Thom
I have Mintex race/fast road pads, and I have to say, they are awesome with rebuilt M030 calipers and all I need in the land of 8 valves. Get your point about serious power upgrades and the need for larger stoppers though.
Stuart
blade7
Well-known member
After getting used to 370 mm discs on one of my daily cars, and tyres that are all done by 2k miles on bikes, you can't have too much of either IMO.Cheers Thom
Stuart
Pulled it all apart and checked it over, regreased it and reassembled with a 12psi spring from Mamba Racing. £16 for the spring and only £20 for the BOV delivered. If it’s terrible then I can fit a genuine one on the same flange but for 10% of the price it’s hard to see how the Tial is over £200 better! Dropped the bits of with my fabricator to weld the flange on and also check the valve and parts for tolerances, etc. Big thumbs up from them so far. Should be a good upgrade for the 25mm Forge valve given all the extra airflow I’m moving now.
blade7
Well-known member
Is that an atmo BOV? Had one on my Cos years ago, I think pigeons were impressed with the noiseAlso received my Chinesium version of a Tial 50mm BOV.
Been blatting around for 5-600 miles of fun and got the dyno booked for the end of June. Due to work and holiday commitments that was the earliest date either of us could do. I’m off to Le Mans in a few weeks - was pondering on taking the Twbo but after a trip out at the weekend that involved dropping MrsEldavo off on the way I think it’s just too noisy and raw for 9 hours schlepping along the motorway.
PSH
Pete
scam75
Well-known member
Bucket seats, KW Clubsport suspension and no sound deadening under the carpets here though!
I'll give you that.........
blade7
Well-known member
Poverty spec seats were a deal breaker when I started looking for a turbo around 17 years ago. Leather sports seats are only bettered by leather pole positions IMO.I'm not a fan of sports seats much prefering the normal comfort type for this reason. BTW, I also love my CHAV sounding BOV....ex Cossie fitment.
Pete
