ORIGINAL: Fen
All you need to do is swap the window mechanism and make a hole in the door card. There is even a cut-out circle in the card itself so it's just the vinyl/cloth trim that needs to be punched through. If you get a LHD passenger side door switch plate (single hole) for your driver's door and 2 968 CS window switch blanks it looks factory. Much easier than trying to hang another door off a different car and then try to get the paint to look right.
You can get manual guts for the standard mirror - mine has teardrops but the 968 CS bits would fit an elephant ear as well as the motor mount and glass pins are the same. It's a plastic bit to replace the motor and glass mount with a ball and socket. It must save literally tens of grammes, but you can also get shot of the wiring loom to the door (completely if you lose the window, speaker and locking as well) plus the switchgear. It's still of limited value TBH - at a guess I might have saved 2.5kg by doing all that.
Edit - actually I forgot the weight of the speakers. It probably is worth gutting all that stuff if you lose them as they themselves are probably a few kg.
