944T Engine Rebuild
- Thread starter barks944
944 turbo cabrio
So far they have been cheapest of what I have found.
I know a company called Wahl in Germany have modified standard pistons for other 2,8 builds in Germany but personally I prefer to be 105% safe and buy new pistons wit a CR of 8,5:1. I'm primarily in it for the better boost and torque build up
Niels
DivineE
ORIGINAL: barks944
Did you use S2 crank, stock rods and aftermarket pistons DivinE?
Sorry just got back to this. S2 crank and Carrillo rods (standard dimensions). The engine ran over 400hp in a 968 race car that was reversed into a wall at 120mph. As far as I know the engine survived and went on in another car.
The kit was bought from Promax before it became Promax motorsport and I think was the Andial kit from the states. The original white 2.8 Promax car still lives too so the 2.8 kit has proved to be quite a reliable way to go.
If I was to do this now I'd probably go for 3 liter or bigger though. If you are buying pistons and rods and having the block machined anyway the difference in total cost isn't that much.
I have dynoed the car once when I bought it four? years ago. It made 320 bhp at 1 bar. Torque was 450 Nm or so. It had a Lindsey sport turbo -what ever that is and a Vitesse MAF. I have been having persistent hesitation problems ever since and the tune is not optimal. I am now changing the turbo and exhaust and possibly engine management as well. I am hoping to get some more power with same boost.
But anyway I think the extra displacement itself doesn't give you much power over the stock. It does have an effect on driveability though. Bigger engine definately feels stronger off boost.
DivineE
ORIGINAL: TTM
The Andial kit included different pistons otherwise they would stick out of the block with standard length Carrillo rods.
Yes the trouble was no one realised the pistons were different when we moved to .5 oversize (because the block was re-bored) so when it was put together the pistons really did stick out of the bores![8|][&o]
Mine were bought about 5 years ago now, but they came in the exact same Mahle box with the same markings on the piston, a friend in the US sourced them for me. At the time they were one of the last sets left in 104mm. These low compression pistons were never available as a standard piston from Porsche in this bore size and were a special commision. Andial had sets made in 104mm and in 104.5mm, they all sold out as far as I am aware although there have been limited batches of the 104.5 that have come out since. I think I have a pic somewhere that I could dig out if you need photographic evidence I can email it to you, the number on the side is 103.98.
ORIGINAL: TTM
why bother with a 104mm bore on a used block?
Purchasing a bare new block doesn't make much financial sense.
But that's exactly what Nick did because he wanted to make a genuine 968 TRS replica from a new bare block. Mahle would have had to produce a few sets of low compression 104mm pistons to cover the handful of genuine 968 TRS that are out there.
The point is that if you are turbo charging your own S2 or 968 engine, you do not have to do anything to the bores, if they are within tolerance and not scored you can just fit these pistons, some carillo rods and a 2.7 head and you are good to go. No need to touch the bores.
