garyw
Moderator
But it will be well within Porsche's expected tolerances.. so the argument runs out of steam with them...ORIGINAL: RJKflyer
However, I will be making it clear that anything less than an absolutely perfect set up will be a punitive experience.
For the 'majority' of owners the factory setting are perfect but for those that do enjoy the car that bit more it just needs that little tweak..
One of the advantages of the Porsche 997 is that it is so tunable to the drivers requirements- I do see that as a bonus but accept that it can work as a negative in some cases where you just want to drive it out of the box.
The point should be made that there are other companies that can do the Geo work for you but as you have read, experience really does count.. [
And Chris has plenty of that experience.
The car is worked upon leaving it still within factory tolerances so does not affect the warranty and is in the region of about £350 for the base work to be done- in balance to the 120K you've spent it's very little money for the rewards it gives.
When Chris first setup his business he toured the Regional meetings showing off his wares, skills and enthusiasm- from there he's become very busy which again says a lot. I'll perhaps speak to him to arrange a register visit in order for the newer owners to see the magic- when you actually see him move the rear camber (all within tolerances) you'll see just how much the car can changed !!
garyw
