- Thread starter daro911
How many more years will Porsche run the current 3.8L for [&:]
"The initial situation was complex," says project manager Jan Roth recalls. "Firstly, it was to increase the distance between the mid-engine and rear-engined sports car. Secondly, the six-cylinder turbo in the 718 would have no place. It was difficult enough, the [link=https://translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=search&rurl=translate.google.co.uk&sl=de&u=http://www.autobild.de/themen/vierzylinder/&usg=ALkJrhiZOIbHEP7c-Et5vHvRs2nohxTjOg]four-cylinder[/link] so accommodating that the charger and its environment is not too much heat. A second loader therefore never an option. " The latest creation of Weissacher pugilists department is a turbocharged direct-injection engine, which will initially be offered in two versions. The 2.0-liter engine mobilized 300 hp and 360 Nm, the larger 2.5-liter propellant charge of the S-model brings it to 340 hp and 400 Nm. Later, to make the duo a trio of around 365 hp GTS.
spyderwhite
That would make perfect sense given the 3.8's age, CO2 and mpg end of an era in Porsche world[&:]spyderwhite said:Imo going by the current info I think you will find the current spyder/ gt4 are the last of the 6 cyl 3.8na!
spyderwhite
But surely that would produce less bhp and more CO2's than the flat 4 2.5 turbo would ever do so why would that botherspyderwhite said:Given that the new engine is called 9A2 (f6 and f4)over the old 9A1 any future incarnation will be based around that and as the f6 3.0 turbo won't fit they could use a 3.0 na flat 6!
plus the current 3.8L was only good for 375-385 bhp in the mid engine models
daro911 said:But surely that would produce less bhp and more CO2's than the flat 4 2.5 turbo would ever do so why would that bother
It is an entirely irrelevant point but 420hp entirely possible and 450hp with Powerpack internals (both available now) ...
spyderwhite
[/quote]
so that will only leave the 2.5 f4 turbo for future hallowed models!
[link=http://www.carmagazine.co.uk/car-reviews/porsche/new-porsche-718-boxster-preview-7-things-we-learned-from-winter-testing/]http://www.carmagazine.co...d-from-winter-testing/[/link]
[h2]4) We haven’t seen the last of the six-cylinder engine...[/h2]You won’t be surprised to hear there’ll be a more powerful still GTS version in the mid-term future, but that’ll use a development of the 2.5-litre four-pot engine wound up to ‘at least’ 365bhp.
But there’s still enough room in the engine bay – and the range – for a naturally aspirated six, for high-performance models like a future Cayman GT4 and Boxster Spyder.
Andrew Killington
tyinsky said:Had 166 from the 987 Spyder. Roof stayed on. Think the reality may be a decibel issue and not the myth that a hood came off on a US journo test.
my roof came off at about 70 mph; in part prompted the recall for the fix (additional bit)
philnotts99
spyderwhite
[h2]4) We haven’t seen the last of the six-cylinder engine...[/h2]"You won’t be surprised to hear there’ll be a more powerful still GTS version in the mid-term future, but that’ll use a development of the 2.5-litre four-pot engine wound up to ‘at least’ 365bhp.
But there’s still enough room in the engine bay – and the range – for a naturally aspirated six, for high-performance models like a future Cayman GT4 and Boxster Spyder." Unquote
but will not a gts version just have a bigger turbo/remap to gain extra 10-15 hp!
I cannot see Porsche building a one off engine for a gt4/spyder,they either use the f4 turbo or a na version of the 3.0l in the 911.you could say they may use a version of the gt3/rs engine but cannot see it and if they do prices will be 6 figures and not 5
And it’s very easy to fall in love with the way Porsche’s new Boxster Spyder looks.
This is the ultimate Boxster. As it needs to be at sixty grand. Lower to the ground by a hefty 20mm, it cuts a gorgeous profile with its roof down, its design a brilliant blend of muscle with deftness of touch.
It’s pretty tidy even with the roof up, too. Which, sadly, was how it stayed during our relentlessly rain-soaked test drive.
So, an open-top sports car in the wet. Not much fun, huh?
And lo, so is a manual gearbox. Which, of course, is lovely to use, gliding from ratio to ratio as you play the 3.8-litre flat six like a musical instrument.
The engine is magnificent, revving with joyous freedom to just under 8000rpm as you stir that fabulous box. No need for turbos here, either – top torque might not come in before 3750rpm, but it’ll still haul itself into life from low speeds in top.
Not that dropping a cog or three is any hardship. Especially not when the pull builds instantly and before you know it you’re being entertained by the Boxster’s sensational dynamics.
The steering wheel caresses your brain with clear, precise information as you turn in, all eager alacrity as the body responds with agile suppleness. It’s pin-sharp but it rides without vices, cossetting you over bad surfaces so you can just relax, enjoy it and never stop wanting more.
And it doesn’t have any turbochargers. While the latest 911 has fallen victim to the inevitable, what we have here is an old fashioned, hairy-chested sportscar with a big, brawling engine and a manual gearbox.
Blimey, for those lucky enough to own one we expect to see you all in cloth caps along with the compulsory Cravat! [
Never seen a hairdresser in cloth cap & cravat ... have you!jdpef356 said:Blimey, for those lucky enough to own one we expect to see you all in cloth caps along with the compulsory Cravat! []
