scam75
Well-known member
I have a SciVision set up on my turbo. It works well. IIRC they were about £800 quid new back in the day. It has a fairly common Bosch MAF element and tube which you can get for about £100 quid now. There is also a little silver electrickery box which converts the MAF signal to AFM language. And there is also an adaptor flange for mating the MAF to the airbox once the AFM is removed (4 x 10mm bolts). There is a loom provided which connects the new MAF to the convertor box, and then connects back into the plug that used to reside in your AFM. There is one splice into the loom required for the signal wire. It was about 30 mins start to finish for the install.
When doing this avoid the cheapo generic Chinese MAF's which can be had for about £25 quid as they tend calculate slower and on my car that made the fuelling go a bit weird although on the plus side it only cost me £25 to identify the MAF element was goosed after I made it drink from a large puddle [&:]. The car at least ran and idled with the cheapo MAF and was back to rude health with a brand new Bosch MAF shortly after!!
Stuart
Stuart
