Balljoint questions.
- Thread starter A5DSR
A5DSR
I'm seriously thinking of the KLA solid mount at £100+VAT for a pair from ESS.
In your opinions will these mounts make much difference to the handling/ride of the car?
Will I have to think about changing any other components?
£100 or £500, no-brainer really.
Daz.
I decided that I wanted to change after driving WUF as he has very direct handling. WUF made Beaky feel decidedly blancmange like in comparison. Subsequent to fitting the top mounts the perceived difference between Beaky and WUF is much reduced.
I've just rebuilt my O/S ball joint for the second time with the rennbay kit, the upper bushing had pulled slightly through the top of the control arm. So I'm looking at getting a rebuilt arm from Hartech, anyone else got theirs from Hartech ?
Whilst under the car over the weekend I noticed that the N/S control arm has already been replaced with the later 968 type (has a mount on the front of the arm for the air dam). Although I can't find the part numbers for them anywhere ?!?
OSF Ball Joint (944 341 148 02?)
NSF Ball Joint (951 351 160 10?)
Did a search on PET and came up with nothing... hmmmmmm.......
Gave the front suspension a good wiggle and now have hardly any play at all on the O/S but a tiny amount on the N/S so am thinking my Strut top mounts need replacing as the movement appears to be coming from that direction. Anybody used the solid spherical mounts from ESS ? Sounds like a steal at £100+VAT per pair compared to the astronomical price for the upgraded turbo items from Porsche.
Also got my new 968 castor mounts today so got to install those at some stage
Dave K.
As I said, I'm looking at a set op top bearings for mine too, the ESS ones at £100 are a steal, but equally, the Lindsey adjustable ones are $250 (about £180?). I've had a lot of contact with Dave, so maybe I could set up a group buy for a few sets. anyone interested....?
A5DSR
I've also ordered a strut brace and a set of poly bushes for the wishbone and ARB. Should tighten things up.
ORIGINAL: pikey7
IIRC, someone came up with the number for the brake duct on rennlist. I'm just off out with the dogs, so if you can't find it, i'll have a look later.
Hi Mike,
Its ok I'm not after the air dam part number just confused as to the part numbers on my control arms
ORIGINAL: pikey7
I've just been looking at the Lindsey Racing top mounts and am not too keen on the ride height being altered plus am not really after that kind of adjustability. So think I will probably go for the mounts from ESS to.
Dave K.
ORIGINAL: pikey7
try racers edge or weltmeister. both stocked by paragon products in the states.
type 911
design 911
porscheshop
All sell the bushes for the control arms.
Dave K.
