Balljoint questions.
- Thread starter A5DSR
sawood12
Apologies for resurrecting this thread again [8|].
I just bought some used 968 control arms from ebay and wanted to check if the ball joints are worn out before I fit them. I can wiggle the ball joint by hand fairly easily, is this ok ? the boots are fine with no tears and otherwise the arms look fine, they even have the brake air ducts attached
Dave K.
I can move the pin quite freely, with just a bit of resistance. Can't really move it up or down though.
The seals aren't cracked or split, just don't want to put them back on if I am going to have to take them off again..
but I'm sure someone who's eminently more qualified to answer will pipe up! [
ORIGINAL: Fen
Didn't Bert say on Titanic a few days ago that you have to fit them to know if they are good?
Hi Fen,
Yes, I fitted my O/S 968 Control arm on the weekend and the ball pin could be moved by hand fairly easily. After fitting it feels much better than the original control arm (ball pin was more difficult to move on old arm). I think maybe that the hardness of the bushing has an effect on how easily the ball pin can be moved ? (I had glass polymer bushes on my old arm).
Dave K.
