I've just finished refurbishing the brakes on my '89 Turbo, including having the Brembo calipers refurbished. It's about 30 years since I last bled the brakes on a car (Mini Cooper I think), so I don't know whether things have moved on since then! I seem to remember that yo start with the caliper furthest away from the master cylinder - presumably with the Brembo's you have to open both bleed screws at the same time? If anyones done the job (successfully!) I'd be very glad of some tips.
Bleeding Brakes
- Thread starter rholt
Hi,
Use a clear plastic tube as it helps to see the amount of air coming through.
Start with the longest, inner bleeder in each corner then repeat in the same sequence on each outer bleeder. Try the pedal and repeat if necessary. Don't re-use the aerated fluid. Once the fluid comes through without air bubbles you should be done (hopefully!)
Long pedal strokes should do the trick but sharp strokes are often effective in dislodging stubborn trapped air.
Good luck.
Regards,
Clive
Good luck.
Regards,
Clive
sawood12
I did a bleed nipple at a time rather than two at once. I also found that once I thought all the air bubbles had been flushed through I could coax a few more out with a few firm thumps on the caliper with my fist. It's a real pain in the backside of a job to do on your own as there is so much jacking up to be done because, as you say, you bleed each wheel that is furthest away from the reservoir in turn. I used one of those onr-man kits from halfords that uses air pressure from the spare tyre so no pumping of the pedal required.
I bought one of these (well a similar one) contrary to most of the advice I read on the forums and wouldn't really recommend it. I don't know if it was my own ineptness or that my calipers are knackered, but it kept sucking air from around the bleed nipples so it was quite hard to see if I'd got all the air out of the system. I think what you really want is something that applies positive pressure to the lid of the reservoir on the master cylinder. There is a great youtube video by irina25661 which shows him connecting an airline via a regulator to an old VW reservoir lid to bleed the clutch (it's a LHD car). Looked much easier!
I can't vouch for how good the fluid is when hot (dot 5.1 works fine for me, but I venture onto the track very rarely) but brakes with bubbles in will show sponginess in the pedal when they are cold and the car is stationary. And in terms of bleeding them, I'm with Rob - an eeze-bleed is the answer if you don't use one already (something like this: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_204645_langId_-1_categoryId_255216). I've never seen the suction type before but can certainly vouch for the positive-pressure types. (I am sure you could make something much more cheaply than the above with some old hosepipe and a lemonade bottle if you wished.) With these, you can simply open each nipple in turn and as long as you have run a litre or so of fluid through the system you will be very unlikely to have any old stuff left in.ORIGINAL: robdimond
When bleeding them, it's worth giving the calipers a bit of a belt with a rubber hammer to dislodge any small air bubbles that may be lurking inside them. The smallest of bubble will make a huge difference to the pedal feel.
ETA: Really stupid question (so stupid you'll have to forgive me asking it) but you are bleeding both of the nipples on each caliper aren't you? >Ahem< Best not ask me why I am asking this .... [
944 man
If you have concerns about contamination and air pockets, then Id suggest buying a flaring too and a roll of pipe, and spending an off-season weekend completely re-piping the car.
Run the new lines inside the cabin and kill two birds with one stone. Thisd be a good time for a new or refurbed master cylinder too, as well as a move up to superior fluid.
If youre still having problems then youll know that its air.
Hilux
Sounds like a fluid issue.
Dot 5.1 is indeed better at high temps so if you are losing pressure via a long pedal in the second stint (is it a quick changeover) you may be getting excessive heat soak into the fluid as the car is stationery for a short period that its brake cooling then struggles to lose in the second for you would normally have a cool down lap at least after a race or track day session.
Are the calipers standard, are the caliper bleed screws on the top? If not remove the calipers and invert them while bleeding.
Any potential air pockets? ie: long curved pipes forming an arch where air can be trapped at the top?
Ballooning rubber pipes can offer a long pedal but you have a solid pedal at the start. Braided lines are nice but hide damage/wear.
People think you can only bleed at the bleed nipples but you can crack off any joint in a brake system as long as the fluid is under the slightest positive pressure (think the same for 944 clutch pipes) but its messier.
Are you getting high pad wear rates? Low pads transfer more heat to the piston so as the race progresses you lose efficiency. Maybe harder pads?
Do you run a servo? Check fluid isnt leaking into it and the seals are good as this would increase pedal effort.
Old pipes? Then I agree with above. Roll of kunifer pipe, flaring tool, renew all pipes, inspect seals and cylinders and renew if dodgy, add a bias valve (if your rules allow) to balance in wet and dry conditions.
PS: I`ve never used one but I am told the suction bleeders are a lot better than pressure bleeders as it attracts the air due to the vacuum
Why is that an advantage? Protecting them from damage? Keeping them warm? Shorter runs from servo to caliper?ORIGINAL: 944 man
Their being inside the cabin, principally.
Gerry - just seen your bit about taking it down to EMC. I've never heard anyone saying that the brakes on a 944 are anything other than excellent when they are in good condition so I'd save Tom's inheritance for sure. Getting them right can't be that difficult and the cost of a couple of hours at EMC will pay for a lot of fluid and bleeding tools for you to experiment with!
I use Motive Power Bleeder. Works every time just great. If you have ABS system, turn ignition on, it helps bleeding process. Start from rear wheels and last front wheel which is closet to main cylinder. If ABS, bleed caliper closest main cylinder before the one which is nearest the ABS pump.
Neil Haughey
Caterracer even the ATE Blue race fluid will boil in my car. From talking to ppl over the years the only fluid that will not boil in these cars under race conditions is the Castrol SRF but it is very expensive. The EMC guys use the ATE fluid, I asked them before about it boiling over in the reservoir, they didn't see it as unusual but we all tend to bleed the fluid out with a load of fresh fluid on a fairly regular basis anyway.
Thanks all, useful stuff!
We don't run the ABS system, and do have SS pipes, so I think we'll try ATE Blue and see if that helps.
The brakes are fine cold, and I didn't have any issues at Donnington for the first 20 minutes but we had a slow change over (my fault being fussy about Tom's HANS) and it cost us about 5 places. Tom then had the long pedal problem.
I think you're right Oli about the fact that cold it's fine, and after a 5 minute cooling off period all is fine again, so it's probably moisture rather than air. Or Dot5.1 boiling.
Maybe the Castrol stuff would fix it.
Hilux
" Dot 5.1 is indeed better at high temps so if you are losing pressure via a long pedal in the second stint (is it a quick changeover) you may be getting excessive heat soak into the fluid as the car is stationery for a short period that its brake cooling then struggles to lose in the second for you would normally have a cool down lap at least after a race or track day session."
S`wat I thought, its heat soak from caliper piston to fluid) on a quick stop after spanking it. Titanium backing plates between pad and piston prevent this to a large degree I am told.
ORIGINAL: Cater_Racer
ATE Blue is not made any more I am pretty sure and what is for sale is old stock. It has a dry boiling point of 280 deg C and a wet boiling point of 198 deg C which is probably fine for lighter cars such as Cateringvans and Westfields etc but is a bit low in my view for heavier cars if being raced.
I use Motul RBF 600 which has a dry boiling point of 312°C and a wet boiling point of 216°C (which is about the same as the new Castrol SRF to be honest) and if you search around is less than 1/3 the cost and readily available on the bay.
Edited to confirm this data from Castrol................
Product Data
Description
Castrol React SRF Racing is a high performance brake fluid of special value in competitive motor sport where extreme braking conditions are encountered. It is an exclusive Castrol product registered under patents in many countries.
Castrol React SRF Racing has an exceptionally high dry boiling point ( typically 320°C ) making it ideal for use under arduous braking conditions such as racing or rallying.
Hilux
ORIGINAL: Neil Haughey
Hi Neil
Look up the Motul RBF 600 as a cost effective alternative (improvement) over ATE [
Sounds sensible... Thanks. I'll definitely go the Titanium Plates route, anyone know a supplier?
We never had problems with our R400 Catering Vehicle, but it was only 515Kgs but 230 BHP made it go quite well despite aerodynamics of a London cab.
we will try a bleed and replace with RFB 600, using the eazi-bleed.
Start front-right, front-left, rear-right, rear-left? Keeping going until the colour changes?
Gerry
Gerry
