Bleeding Brakes
- Thread starter rholt
Monkeythree
Tried leaving the nipples open overnight Colin but it seems that ambient air pressure and gravity were not enough to push the fluid through the system. What it needed was positive pressure on the MC reservoir. I filled and connected my 20yr old Gunsons Eazi bleed this morning and after a brief gurgle there was a satisfying "whoooosh" and the entire contents (about half a pint) of the Eazi bleed bottle injected themselves into the system. After re-filling the Eazi Bleed, I connected up again and then went round all the nipples in turn starting from the rear right and every one came through clean within a second or two.
So it seems that having had the system drained down completely there was simply such a huge volume of air that the small displacement of the MC piston wasn't sufficient to move it and the vacuum pump just didn't have the oooomph to pull the fluid round the tortuous circuit. So handy hint for anyone who needs to refill an empty system is to start with an Eazi Bleed!
Monkeythree
