Bleeding Brakes
- Thread starter rholt
andy watson
Moderator
It is an original 944 option, bit like rocking horse poo I was really lucky to get this off eBay after a prompt from forum member on here after I had posted looking for one, it was still in packaging having never been fitted!
andy watson
Moderator
Heads up - dc performance have another Spax deal on at the moment RSX118 kit ÂŁ626-57 delivered, if you were still interested?
944 man
ORIGINAL: andy watson
Simon - 944man
Only just noticed this Andy.
I refer the honourable gentlemen to my post dated February the first... [
andy watson
Moderator
ORIGINAL: 944 man
Simon - 944man
I refer the honourable gentlemen to my post dated February the first... []
Doh!! [
Hadn't seen that, I am not on commission promise [
My guess is that small bubbles can sometimes catch on the sides of the calipers and take some time to float to the top. Thumping the calipers with a rubber mallet while doing the job can help to dislodge them (a bit more than the 'gentle tap' as espoused by Mr Graham!), but it's not 100%.
924nutter
924nutter
(If you are using the spare tyre method - make sure you have got enough pressure in it beforehand and then lower it to the pressure limit recommended with the kit).
Use AP660 fluid.
Do not drain the fluid totally - not always a problem - but it does introduce air into the system.
Remember - each corner may have TWO bleed nipples. Doesn't really matter which order you bleed these - I start with the outer one each time.
Use a ring spanner on the bleed nipples - don't be tempted to use 'Ein Englander'.
Start at the rear right-hand side, then rear left, then front right and finally front left. i.e. Start with the furthest away from the reservoir.
As you bleed each nipple you will get air bubbles coming out into your jar. Continue for a while as you will not see the smallest air-bubbles.
Try not to let the fluid level drop below minimum level in the reservoir. Top up as necessary - after releasing the pressure. You're likely to use at least a litre for a full system bleed - perhaps 2 litres. Get plenty of back-up supplies - a lot easier than trying to find the fluid you want on a Sunday at 4pm.
You may have to repeat the cycle a few times to get a hard pedal.
andy watson
Moderator
Monkeythree
I'm not convinced by the vacuum pump method because i don't believe the threads on the bleed nipples are airtight so as soon as the nipple is open, the vacuum pump must draw some air down the threads, thus reducing the vacuum effect on the brake line. That's my theory anyway.
As luck would have it, I've managed to find a Gunsons Eazi Bleed in the archives this evening and amazingly I even have a cap which fits the S2 MC reservoir so I'm going to have go with that tomorrow. Mrs M3 is working from home tomorrow so I will recruit her as pedal pusher and hopefully the combination of the Eazi bleed and forced manual labour will do the trick.
If you're having trouble getting fluid to each corner, disconnect at the calliper, push fluid through the line then reconnect. Do this for each corner, then try bleeding as normal.
Some systems can be real pig when fully evacuated. I remember having one system where it was necessary to remove and hold the calliper during bleeding so the bleed nipple was upright in order to expel all the air.
If your still having trouble, it could be a faulty master cylinder.
Regards,
Clive.
