Bodywork Freshen up Teardrop Mirrors and bits.
Fitted then tonight. Not overly impressed yet but have not used them in anger.
Not an e-bay purchase that failed to live up to expectations???
You should have spent the day down here - you might have worn them out.....[;)]
I was really thinking along the lines of someting like a TT where the end of the wiper arm is designed to take the proper flat blades rather than a conversion blade. But I've not seen any modern equivalents that look like they'd fit - also i'm assuming they are the same at the other end. It's only a small detail at the end of the day but I like little trick things like that.
Scott, its possibly vectraitis of the viperbladus, - did the steering go all wooly when you fitted them? - you may find some cheap aftershave would fix it ....[:D][:D][:D][:D]
seriously, I think your plan was a good one, and living on the emerald isle where we need good wipers 11 months of the year, I am planning something similar, - I will weld something like new Mk4 Golf Blades to a scrap set of 944 Arms. I was thinking of wiring a rain sensor too.
don't give up.
George
There is a VW Corrado in the car park at work that has complete wiper arm and blade off a modern car with these new types of blade. Not sure what car they were off or where he got them from. I think it might be a bit keen to leave a note under his wiper blade asking him where he got them. I've noticed that the drivers side wiper blade arm off the brand new Punto looks like it might fit - it has the little 45 degree kink at the bottom of the arm and looks roughly the right length. I know that this seems like a bit of a insignificant thing but I like little details like this and I think the modern wipers are much more sleek and flatter which has got to help styling and performance on a 944 where the wiper blades and arms are completely exposed and don't tuck under the bonnet.
Have you tried Maplins for your wiper rain sensor? They do a series of kits one of which converts your wipers to work with a variable resistor so you can control the time delay between the intermittency of wipers which I thought would be useful for the rear wiper as it annoys me how it can only be on or off and not be switched to intermittent. I think they also do a rain sensor kit as well. Might be worth a look.
ORIGINAL: sawood12
... one of which converts your wipers to work with a variable resistor so you can control the time delay between the intermittency of wipers which I thought would be useful for the rear wiper as it annoys me how it can only be on or off and not be switched to intermittent.
I've pondered that as well, and would have thought that a VW rear wiper relay would work - this gives intermittant wipe, rather than the 944 on-all-the-time behaviour.
I suggested it on Titanic, but was told that the working bits for the rear wiper are no longer available anywhere, and if you over-use it you can expect to strip an irreplacable cog in the mechanism.
I have used the rear wiper very sparingly since then!
On a similar note, the front wiper intermittant wheel annoys me immensely. VW had a much better programmable system, and I have a strong mind to buy a relay from a Mk3 Golf to try that out. I'm 99% sure it would work too.
You can't beat rain sensing IMO - it's the one thing I miss from my BMW that the Audi doesn't have.
ORIGINAL: zcacogp
I agree with the rear wiper issue - I wonder if it's as simple as just changing the relay? (i.e. is it the relay itself that provides the intermittant contact?). If so, that's a well-worth-it mod.
Ian,
I would have thought a replacement relay would be a good start to experiment with. It may be a little different, as the Golf (Mk1, 2 and 3) arrangement has a stalk on the RHS of the steering wheel, and pushing it forwards turned the rear wiper on. The stalk sprung back if you did this (i.e. it didn't stay forwards), and you pushed it forwards again to turn the rear wiper off.
This would suggest that the VW rear wiper relay turns on with a single pulse, and turns off with a single pulse as well. If you fitted one to a 944 you may find that this would give the same behaviour - you would need to switch the console switch on and then off to turn the wiper on, and then turn the switch on and then off again to turn it off. Hence a replacement switch may be an idea (either a sprung rocker or a push-button.)
Have you checked out vw arms? also wouldnt take much to take them to a machine shop and have them shapped?
ORIGINAL: zcacogp
Ian,
I getcha. Vauxhall rear-wipers are a straightforward switch so I might try one of those relays.
Maybe this:
http://cgi.ebay.co.uk/Vauxhall-RELAY-INTERMITENT-REAR-TAILGATE-WIPER_W0QQitemZ180148679195QQihZ008QQcategoryZ10404QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Ian,
That looks like the sort of thing. The legs (contacts) look to be in the usual-ish pattern as well.
Worth a try for a fiver.
That Corrado you talk of with the new wipers on will have Lupo ones, a very common mod amoungst the VW crowd.
Also the rear wiper on a lupo has a very short arm and still one of them new fancy wiper blades.
It's nice to see a modding thread that the normally aspirated guys can get involved in [;)]
Windcsreen wipers, honestly [8|]
Yes I know I'm leaving myself wide open to retaliatory comments about brake mods :ROFLMAO:
Now now Paul.
Don't forget where you started. It was with an S2, as well (I think?)
We can all aspire to nearly 400bhp of jet-fighter-esque oomph, but not everyone will achieve it. At least, not for a while.
(And we have all been driving our P&J's for the last 3 months, instead of providing reports from the bodyshop!)
Any more ideas when yours is back on the road BTW?
ETA: At least I haven't mentioned Quacking here. Yet.
Paul, it's sometimes the small things that make the big impacts! VW Lupo? I wonder if they are the same length as the 944 wipers - they look it. Also i've noticed that both of the wipers are the same on the 944 which makes things simpler. I might have to look into that.
Regarding relays and intermittent wipe. I'm not sure where the intelligence lies with alot of these things. It's like the modern one-touch electric windows on new cars where you touch the electric window button once and it automatically opens. I've often wondered where that intelligence is on new cars as that is also a feature i'd like on my 944. In thoery if you were a bit of an electronics wiz you could make a device that links between the electric window button and the rest of the mechanism that can do this.
