Brakes
- Thread starter Guest
There was a chap on here recently who was proposing to fit the Brembo calipers to his lux, and the consensus was precisely the same; don't bother. The ATE calipers are far more than adequate for the Lux's. As has been said, the 2v 928's were much bigger, heavier and more powerful cars and Porsche deemed the ATE parts to be sufficient for them. (And last time I drove one I couldn't disagree!) If you are feeling that your brakes are lacking in performance then refurbish them (new pads and disks and fluid, make sure the piston is moving as it should and the caliper slides freely) and I suspect that feeling will go away.ORIGINAL: 944 man
I can confirm that the ATE brakes are superb when the cars are young and fresh. People judging them harshly must be basing their opinions on poor pads, old fluid and crusty calipers. As Ive already mentioned: consider where the calipers were used before.
As always, there are owners who want to do 'more' to their cars and get pleasure out of doing so. Nowt wrong with that, but don't be deceived into thinking that it is necessary to fir Brembo parts to make your car stop as it should! [
Although I agree that the 4 pots look a lot better!
Mick
Ex Skyline
1. Do it sooner rather than later, as it's a much easier (and cheaper) job before the corrosion gets fully set in.
2. It's not hard to do DIY - probably an afternoon's job if you are organised, and you don't need any particular tools or parts. There are threads on here about it if you need guidance but it's as easy as it looks.
Sending them away was not cheap, but to be honest I chickened out of doing it myself when I couldn't get the plates off (I'd lined up a local guy to paint the calipers for me). I've been there before with broken bolts and didn't fancy the hassle of completely dismantling the caliper to drill out the stub.
You can get seals and pistons from Frentech at very decent prices, so if you are more brave than me, or don't have stuck plate bolts then it's not too bad of a job. Strangely my rear calipers had torx bolts which came out no bother, but the fronts were allen head and rounded off instantly. Now all torx fitted.
924Srr27l
dlknight said:@PhilKent - yes bit of a lengthy one that [] I'm sure he does a great job but for 4 x calipers it is around £500...
As Phil found Calipers really can be & are a very time consuming job to strip them down and get out the plates and even the Bolts can shear etc...
I've done 2 pairs recently and they really were a pig to do, lots of Heat (LPG Torch) and swearing was the way!
Rather than Paint them, I wanted / needed better Heat dissipation for a Race car application so I had a very thin (Less than 0.1 mm) etch plating (Silver anodised)
R
vitesse
Waylander
I don’t use Torx bolts as most folks have cheap Torx tools, and they strip quicker than Allen heads,
I buy the Boxster sets of seals from eBay, axle set is £24, some bits you don’t use
I used to buy all my parts from Mode Performance, they appear to be a victim of the pandemic and no longer trading
i can rebuild the callipers but I don’t paint them, I don’t have the facilities
PSH
Mind you he has a knack for making things look easy....
Proof that he did do the plates, he supplied photo's for all 4 calibres... here's one with the bolts removed.
and another with the plate itself also removed
Pete
924Srr27l
i should ask my son how he did mine a few months back, that was the first time that the bolts had been removed during my ownership and perhaps the first time ever, that's 34 years of grim and steel on alloy corrosion.
Pete
[/quote]
They don't look too corroded! is your car the early offset up 1986.5 with the smaller Front caliper piston sizes (36 & 38mm) as opposed to the later (36 & 40mm) ?
R
As you know our cars are the same age and possibly the first time the plates have been off since new as well (I've owned it for over 16 years now). Strangely the rears (which are the original calipers) were no bother, but the fronts (which are no longer the original calipers, but the larger late model) where the real pain.
924Srr27l
PSH said:Afraid that I have no idea of the piston sizes Roger, but yes my car is the early offset 86 turbo.
Pete
Ok, then Yes I hadn't researched deep enough and bought some early 944 Turbo front calipers to then only learn they had a smaller
2nd piston (38mm) compared to the later Turbo all S2's and 968#s @ (40mm)
This affects my bias and the power so I've had to source the bigger versions, so will restore and sell these early ones on...
R
PSH
Pete
