scam75
Well-known member
Evening chaps
Further to my mystery vibration issue after having my belts changed I noticed today that the power steering is screeching at full lock either way. Whilst in the garage the PS fluid was changed. Noticed the fluid is bright pink. Any dexron I have ever used in it is dark red. What is this bright pink stuff and could it cause the system to squeal at full lock. Could it also explain my vibration issue if the PS pump is unhappy?
Edit to add bill from garage says "Mobil 1 SHC TQF" which when Googled reveals not very much! I assume this relates the the PS fluid I've been charged for.
Stuart
Stuart
