Bright Pink PS Fluid/Engine Mount Puzzle/Timing Belt - can it jump?
- Thread starter scam75
scam75
Well-known member
Stuart
Sure - admit your mistake and put it right, but to charge extra to put a mistake right is a joke imo!
Still, glad you got your vibrations sorted - hopefully you will come to a fair deal with your indy
scam75
Well-known member
Stuart
pauljmcnulty
Indeed. A letter or email also puts it in writing: essential for tracking who said what, and when. Good luck, they really should make an offer in a case like this!Waylander said:face to face chats tend to get heated when largish sums are involved, I would send him a carefully worded letter first
Over the years many people, specialists, etc had said that the only hydraulic mounts were OE - and that Meyle's description of it being a 'hydro bearing' was false.
So now it seems that at least they are the correct type of mount, just questionable longevity.
I fitted a pair to my 944S, and the quality of mount seemed OK, but I sold the car a short while after, so no clue on their life.
Funnily enough, I am 90% sure I have at least one failure on my 951, both of which have been replaced within the last 10k miles, one by Hartech and one by RGA. Although, it was found that one of these mounts had the longer bolts fitted rather than the short ones, so this could be why one of them has failed prematurely - that and the missing heat shield!
I get some vibration when the weather gets cold, and I'm pretty sure this is due to a worn mount, just need to get underneath and have a measure up really.
He he had them listed as a solid mount and I asked him whether he could confirm that they were solid as I'd seen them listed on ECP's website as a hydro bearing. Max contacted Meyle technical department and forwarded me the email where they confirmed that they were definitely hydro bearings (as Stuart's mechanic discovered). This made Max happy as he could update his website and presumably sell more mounts!
I ordered new shorter bolts as the original bolts were far too long and would definitely knacker the mount.
