I've had a LHD 944 and LHD 968 - both sold to buyers from continental Europe (944 to France, 968 to Germany), and both went for decent money.
Mick
Mick
Of course it's overpriced. It's a dealer. But need to start somewhere. If mileage is real and there is no rust and all parts original , might be worth a look...
ORIGINAL: pauljmcnulty
Well said! I'm probably the most cautious person on here, as I've seen too many people buy badly and then ask the questions on the forum...[&o]
My S2 seemed a bargain at about £4.5K, but in the first two years cost me £7K in servicing. Plus, it then had the (non-existent) rust show through, so has had the corrosion dealt with and a respray. So, in reality, it's a £14K S2. [&o]
Honestly, and I'm not talking here to you guys who DIY so don't factor in your time and expertise (you'd need to say at least £40 per hour for what you DIY on your cars to be fair here), what decent 944 isn't either a £10K car, or potentially a £10K car!
If this is as good as described, it's worth the asking price IMO.
That said, there are plenty of things to consider. Firstly, all parts clearly aren't original, as the seller states. Does that matter? Not at all, as a carefully improved turbo is a better car than an original one. You need to check the mileage and history with a fine-toothed comb, and see cetailed photos of the respray to see what was done, and what was underneath.
It says "rust-free". Unless a car is sealed from new in a vacuum, it will have corrosion somewhere. It might LOOK rust free, but inside the sills and behind the front wing liners will be some corrosion at least. If a 944 is trully rust-free then buy it, whatever the price! What you're looking for is the best for the money, which might mean someone has restored it properly, with pictures, or buying cheap and budgeting to do a full restoration and respray yourself.
As with any car, you need to look at what might be about to rear it's head: a low-mileage 944 can be a real money-pit. This one's done 79K miles according to the ad, so that immediately points to problems you need to ask about. For instance, the clutch has a rubber centre that breaks up over time, so has it been replaced? If not, that's a grand. The brake calipers corrode, and the lines need replacing. At least a grand. The fuel lines fail, to replace properly expect nearly a grand. All the rubbers will need replacing, and with door, hatch, sunroof etc. that's £500 in parts. Are the tyres legal, but out of date and need changing?
Full history sounds great, but what's actually been done? We hear of cars being sold with belts only 5K miles ago, but neglect to mention that they are ten years overdue. A belt service might well need a water pump, oil seals etc., and could easily be (you guessed it) a grand! Does it need gearbox oil, brake fluid, coolant, it all adds up.
I'm not trying to be negative here. The 944 really does have no real competition if you want a 1980s/90s coupe with proper peformance, incredible build quality and great parts availability. You just need to go in with a proper budget, and buy the best as they are so undervalued. Ask all the questions, get pictures of the inside of the sills. Get scans of the history and look at the last few years only: who cares that it had wiper blades in 1988, you want to see belts and a clutch recently if possible, along with brakes overhauled, fuel lines dealt with, even little things like new HT leads that cause so many problems.
Hope that helps. You need to go in armed with all the right questions, listen to the answers and then decide if the car's the right one for you, and your budget. []
ORIGINAL: soli
does anyone live close to this car and maybe wants to have a look with me over the weekend?
ORIGINAL: soli
for that one I will need to get a car... not easy on the train. the LHD easy from London Kings Cross...
ORIGINAL: 944Turbo
DavidL's is here, didn't realise it was still for sale
http://www.porscheclubgbforum.com/tm.asp?m=785397&mpage=1&key=򿯵
Tony
