confession time .That means you !
hiya all. 1] refurb wheels, 2] get tailgate to open. 3] visit to daytona for paintwork to front end and roof, so all panels match.... and thats about it although i am almost sure some other little niggle will crop up cheers jsaon
Fix drivers electric window (new motor required)
Finally replace the P6000's all round
Replace oil pressure sender
continue search for the missing 30HP [:eek:]
Howard
Since my yoke hasnt been about in over a year my list looks like
1) Refit door handle - LH window and door card
2) Sort out US alarm system - Needs new barrel (10 years [:D])
3) Worn wishbones
4) Belts and pump
5) Make up NCT friendly indicator units
6) Replace both headlights one is shabby the other is cracked
7) Heated rear screen broken lug.. (8 years [:D])
8) Drivers side door check strap (10 years [:'(])
9) Boot lock no key (10 years [&o])
10) Airbag needs clockspring fitted (last year)
11) Broken foglight ( 2 years)
12) bonnet struts ( 3rd time...)
I am going to have a priority list made from this list.... Its going to take a fare few evenings to do all this [:D]
Ahhh missed Bonnet Struts! If I fix them I won't have to carry the lump of wood in the back to wedge under the existing saggy struts.....
ORIGINAL: VanhireBoys
congratulations !..... you have now discovered the wonder of 'LISTS' [:D][:D]
from now on all you need ever do is update and prioritize your 'LIST' every day and you need never actually 'do' anything [;)]
Another new one to add after today: Drivers door handle sticks when squeezed, doesn't spring back until you slam the door shut..not a biggie but an annoyance!
ORIGINAL: Fat Albert
That one's easy!
- Take door handle off (one screw, on door shut)
- Clean the crud off the handle with some WD40 (or similar)
- Apply a very light trace of very light oil (everyman or similar)
- Re-attach handle to door
Given your bravery in doing the brake calipers in the cold, this one will be a doddle for you! [:)]
Thanks Oli!
Will have a crack at it over the weekend
I sorted the hatch release over the weekend as well, that had got very, very stiff and I thought I was going to break the key at one point
jobs done:-
replace the frond indicator lenses to clear
full service
interior clean
to do:-
belts
rear screen replacement.
There do seem to be a lot of people on here who are meaning to do belts ... either we are an over-cautious lot with a long to-do list, or there are a lot of 944's around with old belts on them.
Which is it?
um...
1. get car out of storage...check
2. put up on axle stands...check
3. remove engine and rebuild....arse
4. everything else that goes wit the above....arse
ah well...there's always next year........
ORIGINAL: zcacogp
I'm guessing that we're over-cautious. Every year, I ask my usual mechanic to "˜do the belts' when he's servicing the car. Every year so far he's said "I checked the belts, no need to worry about them yet."
- Cure oil blockage
- Belts and water pump
- Oil cooler seals
- Put engine back in car
- New brakes
- New windscreen
- Sort out dodgy fibreglass front bumper
- Driver's seat belt
- New wipers
- New shocks front and back
In other words enough to keep me busy for a while longer. Still it's been off the road for 10 years, a little while longer won't hurt.
forgot about the bonnet struts, and one of the motors in the drivers seat aint working., oh, and replace the boot lock seal too :)
erm, think thats it, for noo anyhoos...............................[:D]
Talking of struts since when did a proper pair of rear hatch struts cost so much? £70!!
Anyone bought any any cheaper recently that have the correct electrical connections?
ORIGINAL: DavidL
Yep - £15 each for OEM struts at Promax and I can happily report my heated rear window has been utilised fully this week (oh and the boot light works too)
ORIGINAL: madrob6
- Cure oil blockage
- Oil cooler seals
- New brakes
- New windscreen
- New wipers
mmmm not too much then Rob [:D] couple of weekends should do it.....
ORIGINAL: peanut
Considering everything I've done to it so far it isn't very much at all. If I didn't mind my fingers falling off or my bank account being wiped out I could get it done fairly swiftly but then its maiden voyage would be in the current fine weather which I don't fancy much.
I'll carry on the previous pace of it'll be done when it's done. It's only taken 2 years so far, what's another eh? ;)
