Yikes! Good luck![ORIGINAL: Giff Ordered some EBC yellowstuff too.
Do i have to use OPC for brake pad change to keep my warranty?
- Thread starter jhrfc
Why do you say that?ORIGINAL: tscaptainYikes! Good luck![ORIGINAL: Giff Ordered some EBC yellowstuff too.]
I went with the pagids when I replaced my front discs. Done about 1500 miles on them and there are no signs of wear. I have done some pretty hard braking as well [
Giff
Paint wise I use an acid etch primer for both discs and calipers, the discs are then coated in smoothrite before VHT high temp lacquer. It's one of those little known things that smoothrite was originally designed as a high temp paint. The calipers have to be sprayed with VHT colour and are wet sanded so the decals can be applied before three coats of the VHT lacquer. Shall post a pick when they are fitted although you probably won't appreciate the colour I've chosen for the calipers!
Tried red and yellow on various cars previously and they fell to bits - well the surfaces became very crazed. Wouldn't put them on my Porsche - Pagid RS 29s for me![ORIGINAL: Andy FaganWhy do you say that? I've used them for a while and found them to be ok on track and road.ORIGINAL: tscaptainYikes! Good luck![ORIGINAL: Giff Ordered some EBC yellowstuff too.]
Maplins sell an aerosol called label remover. It works a treat on the residue from the weights and also removes the tar spots inside the rimsORIGINAL: Giff Need to get those old weight adhesives off..
Chris_in_the_UK
Lovely!! Here is one of mine..................
Chris_in_the_UK
No mate - PCCB discs and callipers.......
ORIGINAL: Giff Fair play that looks a quality job! Did you wet sand before adding the decals?
Chris_in_the_UK
Spec'd by original owner when new. Std handbrake arrangement.
ORIGINAL: Giff Of course! Was the conversion a big job? Does the handbrake still actuate within the steel bell?
