Just a couple of quick points to note about brakes:
1. You are talking about drilled holes not cast holes a la factory 996 etc
2. Even factory discs with cast holes crack - ask someone who races
3. Discs with drilled holes crack faster than cast holes - but for road use this is basically irrelevant
4. Why do discs warp? 99 out of 100 it is because the car is parked with hot pads next to just one spot on the disc (or the handbrake is on). Solution is to roll the car a half metre or so every minute for a few minutes so heat transfers to multiple spots - and leave the handbrake off
5. Discs do not warp when the car is in motion as there is no unequal rate of expansion
6. All 911s have vented discs.
7. All serious race cars run grooved discs now - to vent gases principally but I guess dust also
8. Drilled discs look cool
9. A solid disc provides you with a bigger heat sink - a drilled disc may cool *slightly* quicker
10. Cool air ducted to the centre of the hub will do much more than a few holes in the discs for cooling
11. Slotted discs cost a fortune and may not be available for our cars anyway (although a call to Demon Tweeks would net a quick answer as they carry all major brands)
12. EBC Green pads are not an "upgrade". Put your hand in your pocket and get some decent pads like Pagid Blue or Porterfield (or even Mintex 1144s) [
13. Replacing just the rear discs will have no major effect - feel free to experiment.
14. Do not replace just the rear pads [
15. Brake bias is mainly a function of the piston size in the calipers. In the 3.2, the pistons are the same size front and rear but a proportioning valve operates over a certain pressure level to reduce the rear brake pressure and avert rear end lock up (maybe 33psi?). The aim of this is to even up front/rear wear in normal driving. It is unfortunately the worst bias of any 911 - until the proportioning valve kicks in.
16. If your 3.2 brakes wear evenly front/rear, then you are not braking hard enough [
17. You can heat up your brakes by applying them with the middle pedal. This works for drilled or non-drilled [
] Your cross drilled will not stay sooo cool that heating up is a problem
I could go on but that is enough for now. Feel free to raise specific questions.
RB
