marcoturbo
Rotten head ?
Yes the wiring is fine. Adjusting ignition retard with the FQS has a direct effect on knock and there are hardly any left with the FQS set on -2°, but by then the engine feels less responsive. I am not sure where to start to get rid of this. As knock disappears when peak boost is reached I am tempted to think that the air that gets into the engine is fresh enough and fitting a "more efficient" intercooler might prove useless.ORIGINAL: 944Turbo Knock - is the wiring ok to the sensor? Do you have an alternate one to try?
Yes this makes sense ; Sly hasn't yet taken the valves off the head to check.ORIGINAL: A9XXC Valve / valve guide on No 4?
Not really. I'm not speaking from any experience on the subject but I'd have thought logically that if you've been using light throttle a pump with insufficient flow would have had a chance to build up pressure (like putting your finger over a garden hose) so you'd have best pressure as you first open the throttle, weakening of as the boost and revs built to maximum demand. One thought I had reading this was that the mapping is always designed to lean the mixture just before the turbo spools to encourage earlier spool up, then get richer to protect the car as the boost builds. If the shape of the map was now out of sync with the spooling of the turbo due to the extra capacity.. the map could be going lean temporarily as the boost is building causing knock. Did you ever sort the white smoke from the exhaust problem which went away after some full throttle?ORIGINAL: TTM Quick update. Sly took the valves off the head. Exhaust valve guides show a surprisingly high level of play, usually observed on heads that have three times the mileage. Exhaust valves used are heavier than the original ones and are not filled with sodium, which probably caused the guides to wear more quickly than expected. As exhaust guides are equally worn, this doesn't really explain why oil made its way into cylinder #4. The "lean spike" that takes place on my car when I floor the throttle and the related knock blink observed may be caused by still using the original fuel pump. 83lbs injectors (more than twice the output of the originals) may cause for a short moment a drop of fuel pressure in the fuel rail when opening the throttle wide - does that make sense?
Hi there, I guess I have somewhat similar problem with my 2.8 stroker engine. Wideband shows lean condition briefly when accelerating rapidly and car stumbles once before it gets going. It seems to happen around the point when the manifold pressure changes from vacuum to boost. It kind of feels like it hangs a second too long on closed loop until it goes to WOT maps. After that single stumble AFR's are ok all the way to the redline. I have Vitesse software and Maf along with associated mods. Fuel pump is stock though. I have chased the cause for this for some time now. I have changed many obvious parts as TPS, plugs, distributor cap, O2 sensor etc. Fuel injectors have also been professionally cleaned but the problem still exists. It doesn't stumble with cold engine though but that's because the car runs quite rich while warming up? I will change new(bigger) injectors and install resistors to get proper resistance. Also have to try with another DME box.. could be there's some heat related damage because running those injectors without resistors?? (I doubt it though) Might also install new fuel pump and the check valve next to it. I guess it would be logical to suspect the Maf itself too.. [8|] I asked John to update the sofware to latest version but it costs 600$ so I am not very keen to try that at the moment. Problems like that get very frustrating very quickly.. and the troubleshooting gets expensive while many parts have to be changed when the root of the problem can't be found. [ORIGINAL: TTM The "lean spike" that takes place on my car when I floor the throttle and the related knock blink observed may be caused by still using the original fuel pump. 83lbs injectors (more than twice the output of the originals) may cause for a short moment a drop of fuel pressure in the fuel rail when opening the throttle wide - does that make sense?
