Engine build progress
- Thread starter TTM
marcoturbo
TTM
Well-known member
Hi Jarmo, Thanks for the feedback. At this point I want to believe it will all get solved when upgrading the fuel pump. The problem happens also when applying minimal load when cruising - let's say you drive your car at 120kph in 5th, with 0.4bar on the dash gauge, then you lightly increase load so the needle goes to 0.9bar. In that case I see the AFR jumping for about 1/4 of a second to 15-something then goes to 12 which is a more acceptable value. If it's not the fuel delivery then perhaps it's the Bosch/Vitesse stuff that can't keep up but as two mates here have had the same problem since day 1 I would rule out a faulty MAF sensor. Perhaps there is something wrong somewhere in the wiring loom but again, it would be strange to have the exact same problem on four different cars. You have this problem as well and you did the wiring on your side so the same fault done during the installation would be surprising. PS : What turbo are you running?ORIGINAL: JarmoL I have Vitesse software and Maf along with associated mods. Fuel pump is stock though.
TTM
Well-known member
The fuel pressure regulator is new but the damper isn't. Jarmo replaced all these items yet it didn't seem to help, so I think the next step is to upgrade the fuel pump and see what happens.ORIGINAL: barks944 If the car is running lean then under those conditions its either the injector pulse width too low or the fuel delivery system is failing to keep the pressure differential between manifold and fuel rail correct. Finding out which is probably key to finding your problem. I guess the fuel pump runs at a constant flow rate, so as your not really testing the flow rate of the pump at low rpm it may be the fuel pressure regulation. Damper and or regulator not doing its job.
Hi there, Sorry I didn't mention that.. but yes.. both the damper and regulator have also been changed. I also have an adjustable FPR but the problem doesn't go away with that either. I guess one more thing to check (or rebuild) would be the wiring from TPS to DME. Could too much resistance there translate to slight delay to throttle inputs? Thom: I am currently running a Lindsey "sport" turbo. It's the one with 10cm hot side. I have bought a Garrett GT30 but it's been waiting for a right moment to install.. maybe next summer. [ORIGINAL: barks944 Fuel rail pressure should be increasing at the at the same rate as boost pressure. It sounds like the fuel rail pressure isn't increasing quickly enough. The conditions you are talking about probably represent the highes rate of change of fuel flow with the onset of boost. These conditions are most challenging to the pressure regulation system. The fuel pump is always pumping at full flow rate afaik so its not having to speed up or anything. I'd say its probably the pressure regulator or damper. Check the boost line to the regulator as a start, are they new components? Edit: Are you sure jarmo changed his, I can't see where he said that!
Diver944
I have an uprated fuel pump and I certainly haven't seen this momentary lean problem from the Vitesse MAF [&:]ORIGINAL: JarmoL Who knows.. maybe they all have updated their fuel pumps and that indeed is the answer!
TTM
Well-known member
For what it's worth John @Vitesse keeps telling me I can solve the issue with the Piggyback by adding fuel, but it just isn't the case. He has never strongly insisted on selling me an upgraded fuel pump either as apart from that the fueling is "safe" on my car.ORIGINAL: JarmoL I have to say it's a little worrying to hear that you guys are also having those "weird" fueling problems. I haven't seen anyone complain at the Rennlist though.. Who knows.. maybe they all have updated their fuel pumps and that indeed is the answer!
TTM
Well-known member
I wish there was a way to adjust the fuel maps in 3 D. I have only a Mafterburner and that is quite simple tool. I have tried to adjust fueling to my best knowledge but it doesn't make any difference to that lean spot. I have spoken to Vitesse about my issue and he is pretty confident it's not the software causing the symptoms. (And that makes sense as he seem to have so many satisfied customers with no problems) Anyway.. I'll try another set of injectors (this time with resistors) and will also install a new fuel pump as the current one has seen over 200000 in kilometers. I have two intakes for my car: one stock with stock t-body and the other with a flange from S2's intake. S2 throttle body is a little bigger in diameter so previous owner mixed some parts from 951 t-body into S2 t-body to make it work. I have a custom IC and custom IC piping (mine's a 968) but I haven't noticed any diffence in how the car drives with either t-body so I'll keep using the the stock one.ORIGINAL: 333pg333 Thom I'm sure I've read others with the same symptoms as you and Jarmo. Just can't quite remember where. I'd think Rennlist. I know I see you both on there from time to time. Obviously you've spoken to John. From my dealings with him he is pretty methodical in problem solving. Seems like you need to have fuel increased on a 3-D partial throttle map. I'd do a bit more poking around on Rennlist. Maybe try Pelican too. So you both have stock intercoolers and fuel pumps? I don't know much about TPS but you would assume that it's really just measuring exactly that, "Throttle Position Switch"? So why can't the electronics be morphed onto other T-Bodies? I know where you can get a larger one that does work but they're custom and not cheap.
DivineE
TTM
Well-known member
