Engine Oil - 2.7 - what do you use
- Thread starter AntB
Neil Haughey
Still though if one is loosing oil when hot with a 5w-40 oil I can't see how moving to a 10w or 15w 40 oil will make any difference.
944 man
Simon
eta: beaten to it by Neil: I took far too long checking... []
944 man
ORIGINAL: Neil Haughey
I agree; and I cant really see how a chemically superior and far more stable top quality ester based synthetic, like Im using, can lose me 15psi of oil pressure across the range when hot either, but it does...
Exactly.ORIGINAL: 944 man
15 W-40 or 20 W-50 according to the owners manual, suitable for temperatures down to -15c.
Cold start and cold load are when the motors get worn the most. Having a thin light w version won't leave much residual oil up in the camshaft / tappet region. Especially if the car has been sitting for a while. Interestingly Mobil have re introduced ZDDP content into some of their performance oils. Perhaps they've been reading some forums?
Neil Haughey
I have heard it before many times that engines from the 80's often don't get on with modern synthetic oils. I can remember back with my old 900 it was often said that the synthetic oils reacted with the material they used back then for the engine seals. I was never sure but I did know of several ppl that had engines that started leaking like a sieve as soon as they switched to synthetic oil, even if the synthetic had the same grade. Still though this doesn't explain the observation you get Simon but could in theory explain why sometimes ppl get a lot of oil loss with Synthetics.ORIGINAL: 944 man
Hilux
Agree absolutely hence my comments re tolerances also. Its all very well having a thin viscous oil at cold start but if its designed for very high tolerance quality then its less effective in lower tolerance older or worn engines (thats what I think anyway)
sawood12
I simply don't understand how a thicker oil is going to improve cold start protection and running - it goes against logic, common sense and all advice and recommendations i've ever had from anyone in the know, Porsche specialists included. I'd love for someone to explain this in engineering terms.
Also alot of the myths and folklore about synthetic oils originated from their early days when they were still being developed and probably did have some problems. Modern synthetic oils are a different prospect altogether. In fact is there has probably been more technological developments and advances in motor oils over the last 20yrs than any other aspect of the car.
Anyway we can argue about the logic, but the manual is the manual and it seems I may have misread it!!![] Just looking at my Owners Hanbook as I type against recommended multigrade oils. Seems like the 5w rating is just outside actually, which surprises me as i'm sure I referred to the handbook when choosing my grade of oil. For multigrade oils and climatic temps the manual recommends :-
-30 - 0 = 5w30
-15 - +20 = 10w30
-20 - +35 = 10w40/10w50
-15 - +40 and over = 15w40/15w50
-10 - +40 and over = 20w50
Looks like 10w40 next time for me. But i'm convinced a modern 5w40 gives better cold start protection than a 20yr old 10w40.
Neil Haughey
A fully/semi synthetic oil has additives in it that reduce the decrease in the viscosity of an oil as its temperature increases, it still gets thinner just not as much as it would. The reason to do this is so you can have a thin oil at low temperature for cold starts and not end up with a really thin oil at high temperatures that leaks all over the place. This is where the kind of rating 4w40 comes from and it means that at low temperatures (ambient?) the oil will have a viscosity of a grade 4 oil and at high temperatures (running temp?) the oil will have the viscosity of a grade 40 oil. Remember the number does not denote the actual viscosity it only tells you what grade of oil the synthetic oil is behaving like at the given temperature. For example a synthetic oil could actually have the same viscosity at low and high temperatures. Essentially it means the effective grade of the oil changes with temperature so its like having multiple grades of oil within one oil and picking the grade you want for a given temperatre to give you the viscosity you need. Its very clever stuff.
Another thing to note is that the charachteristics of an oil go beyond viscosity. For example if you take a fully synthetic oil and a synthetic oil of the same viscosity a fully synthetic oil will have a greater tendency to leak through gaps due the synthetic oil having a greater surface tension (im not sure exactly what you call it). For example this is what causes water to form globules rather than spread completely flat, on your windscreen for example, whereas oil tends to flow out flat. I think a synthetic oil has a greater surface tension than fully synthetic oil and thus should help stop leaks.
tr7v8
An oil rating is just that if you had a SAE 40 oil (mono grade but I know it doesn't exist) that means it has a given viscosity at a set temperature.
This viscosity applies whether it is lemonade, petrol, mineral oil, synthetic or whatever. An SAE 40 Synthetic has the same viscosity as an SAE 40 Mineral.
The reason that people frequently complain about oil consumption with synthetics is twofold
A. It used to be the case that most synthetics are lower viscosity so most were launched as 5/40 or 0/40 or even 0/30 although that did change later
as performance oils were launched like Castrol RS20/60. They were designed for low fuel consumption & very tight tolerances used in modern engines.
Synthetics also give longer intervals between services so less cost for the fleet market.
B. Synthetics are very good at scouring the engine clean, this tends to remove carbon deposits & therefore seep past rings & seals that were not an issue before.
tr7v8
That is why my Valvoline is called 20/50 & this is a mineral, assuming your not running anything made pre-war then none of the oils "our" cars use is a monograde oil.
The additives keep the oil in grade & also give detergent abilities etc. Some of the additives will be zinc which protects high pressure areas such as the cam & followers.
Zinc is being reduced in modern oils because it gives issues with Catalytic converters, another reason why older style oils 'may' be better.
Edit: wiki says additives called viscosity index improvers are what make an oil multi grade. So its nothing to do with it being synthetic but it is down to the additives to make it multi grade. Synthetic oils are chemically constructed oils rather than being mineral oils. Semi synthetics are a mix of mineral oils and synthetic oils.
tr7v8
Correct & that is the same whatever it is made of.ORIGINAL: barks944
Isn't calling it multi grade just describing the fact that it behaves like different grades of oil at different temps? If so what is it that causes it to be multi-grade?
Hilux
How is using a thick oil going to improve that situation? Surely it is easier for an engine to suck up a thick oil than it is a thin oil?
Its not its just that a thicker oil doesnt run off the surfaces.
ISTR the problem with top end wear is allegedly due to the thin oils running out of the head when the car is sat, hence when started up, the engine for a few seconds has very little or no oil on the camshafts etc. I have no idea how true this is but there does seem to be anecdotal evidence that cars run with thicker oils have shown much less top end wear. ISTR an Australian 928 specialist had some stuff about this on his website.
Slowly but surely the truth will out. Of course thin oils in an engine designed for 20-50 will drain down at cold temps, they are designed to be more viscous at low temps!
IIRC Mobil 1 is a `cracked` mineral oil and not fully synthesised.
Just read this thread guys, it explains it all clearly.ORIGINAL: 333pg333
Here is a very comprehensive oil thread. Yes it is long. No, I'm not sure if all the oils in there are available in the UK. Charles Navarro is an expert and well worth listening to.
http://forums.pelicanparts.com/showthread.php?t=367300
Many people are using the wrong oil in their Porsches. Don't be fooled by what Porsche recommend at times either!! They have some commercial alliances that are more important to them than their customers old cars.
+ Here's the link to the aforementioned Aussie front engine specialist. Read this as well.
http://www.landsharkoz.com/tech/bb/bbipr.htm
944 man
ORIGINAL: Hilux
Yes, but Mobil only came clean when they were caught out. I believe that they claimed that it was a 100% ester-based oil, until the results of a gas spectrun analysis revealed that it was indeed mineral oil based. This is quite legal though because the term 'synthetic' carries no real meaning.....
