Diver944 said:
GPF said:
As for timescales they said with a project like this they like to charge by the month.......not sure about that!!
Eek
I think it's time to do the same thing with my S2 this year. The oil consumption is getting silly now and I know it is very much down on power. I couldn't live without it for months though, hopefully weeks, and I don't think I could stretch to OPC prices either
Hi Paul
It's frightening how much rebuilding a 944 engine actually costs, I couldn't have done it if paying someone, most certainly not an OPC. Rebuild parts are crazy too...IIRC a genuine set of oversized (actually undersized) bearings are around 3 to 4 times the cost of a standard set, I wouldn't advise using aftermarket parts here though.
Graham, regarding machining I can fully recommend SERDI UK based in Uxbridge, they should be able to source pistons if the bores are out of spec too. Be sure to get new sleeves machined for the rods, IIRC they are only brass, I guarantee you that these will be worn now and this is the only real weak point on these great engines, in particular for Rod no. 2, especially if the car is used on track.
Regarding some of the other points mentioned
crank scraper... most certainly, it helps greatly in the response of the engine not having all that mass stuck to the crank.
Lightened flywheel...I'm not a fan of going overboard here, nor would I use a lightened crank, not unless you want a racing car for santa pod or such, for a road car...no. However, having said that my own flywheel has been machined to remove all of the scorings, this, in fact, is now down to just below Porsche's minimum so I guess in essence is a little lightened. I would most certainly advise having the flywheel machined to remove any marks, the clutch will work far better and last longer too.
Good luck with the build, there's nothing quite like a nice new fresh engine, well not once your head has accepted that nothing is going to fail.....I'm very much loving mine of late....
Pete
