TTM
Well-known member
Hi Graham,
Sorry if this sounds a bit rude but any (serious) machine shop would not rebore a block without having the pistons in hand to make sure they are doing it within the correct tolerances.
Also, the 0.005 mm clearance works well with standard engines back when they were new and running low boost, and I don't believe you will want to run it in stock configuration.
We all got away with tuning them up as when we bought them they were already quite a bit worn and could handle more boost and abuse without scratching the bores (too much). I would not use the standard tolerances on a modified engine. A bit looser is better and safer.
At least that's my experience and that seems to be a general consensus between all the folks and machine shops I have talked with.
