We have recently been spending a lot of time and thought on engine cooling for two quite different projects - the 500bhp 3 litre 944/968 based turbo stage 2 project and the problem of 996 3.6, 997 and Cayman S piston seizures and bore scoring. These involved building engines with temperature sensors and on going road tests etc.
The results will be published soon - but they enabled me to resolve a concern I have had for many years - why some 944's (especially turbos) but mainly 944 S2's (and some 968's) suddenly seize up a cylinder or two after running OK for many years and despite there often not being much else apparently wrong with the engine or car.
We are completely changing the coolant flow inside the big turbo engine (for better cooling) because originally it flowed backwards down the block then up through the head gasket and forwards accross the head to the front outlet. Despite there being many coolant passages apparent from the block to the head - the head gasket shields most of those except those at the rear (where the flow passes up to the head).
Usually when we receive an engine or car with a damaged cylinder or two - the head is off and we don't even get to see the head gasket - but I realised that by now (if they are still original) they are all rotting away and this first creates holes between the block and the head where the coolant channels were originally blocked off by the gasket - creating a "short circuit" and preventing the coolant going all the way to the back before coming forward again - creating a hot spot at the rear being hardly cooled at all. Under heavy acceleration the oil may well flow backwards and help cool the No 4 cylinder but No 2 & 3 will probably suffer most (the most common we see seized).
This will be worse in the 2.7, S2 and 968 block because the coolant depth in the cylinders is less and there is only (not two) coolant inlets to the block.
So when the gaskets rot - the engine will run too hot near the cylinder walls - mainly centre and rear (where they usually go). The sealing of the head may still be OK at this point - so anyone with a car that has never had a head gasket by now - I would strongly recomend they get one fiited as a preventative measure.
Baz
Baz
