Hi Alexw, I think all big capacity 944 based turbos have exhaust flow restriction. This is why most (except perhaps those with extensive head work and large exhaust systems) produce too much mid range torque for a track car or too sudden a boost spike to control out of corners.
You can overcome inlet restriction by more boost but not exhaust. The 16 Valve head has more flow capacity and also provides the opportunity to experiment with negative valve overlap via the variocam adjustment system. There is a difference of opinion over the benefit of this and I don't know for sure what the answer is but I will be finding out when this lot is running OK.
Unusually instead of re-welding the head or block to fit an 8 valve head to a 3.0 block I have adopted a 2.5 block and welded the block to accept a 3.0 16 valve head (because there are deeper coolant channels that I want to exploit to improve cooling).
Once we discover what the answer to the overlap situation is it can then be exploited in later engines that also have a variocam system - like all M96 and M97 engines.
It will take a while to get the whole thing running with stand alone systems and then to experiment with different cam timing etc - but at least it will fill in some blanks in our knowledge that need understanding better.
Baz
Baz
