Chris,
I dont think Anti freeze will harm a stored engine in any way, one point to note is that excessive antifreeze may reduce the protection from freezing.......only heard that recently.
What I was going to say regarding the head gasket subject; - it may not appear as a replacement part for any scheduled servicing (as the timing belt does for example), but the original fit part as manufactured by Victor Reinz does corrode and the waterways therefore become seriously compromised.
I have seen this on a 951, 110k mile approx, hot day, 1.2bar VDO measured Boost, lots of beans in 3rd gear overtake, 4 seconds later.....hiccup in power delivery.......pfffffffff, condensation from exhaust with 30degC ambient, coolant tank pressure.......rear-most cylinder gasket had popped when I got the head off. (I did not overheat the engine)
If I consider the theories being made here, I am 100% certain they are correct, - the gaskets the bean counters permitted on the production line were never intended to last 20 years. (they contain mild steel !!!!! mine was basically rotten)
My Cometic Gasket has behaved perfectly since - it is obviously superior for general use up to perhaps 330bhp, - the real big power tuners will use bronze o-ringed heads perhaps. I did not need to skim the head on mine as it was not cooked and the faces were perfect.
Baz, I appreciate the thought and effort you have made to share your findings publicly, I always wondered why these engines are known to fail nearest the bulkhead.
The steam vent upgrade is also a nice idea, even as a precaution - it also offers a tiny but perhaps significant coolant flow path out of the back of the engine (can the head casting profile vent air without it?)
Porsche's accountants have created a challenge for your specialist automotive-engineering business.
I think Porsche still plan to offer marginal engineering design quality in their regular (non GT) sports car products, and perhaps also in the GT's of the future as DFI is adopted and the old GT1 engine family is phased out
Good luck with the 997 scoring issues, there are a lot of folk depending on a result.
George
