Engine Upgrade
- Thread starter cornishgrose
Diver944
big Turbo £800
new S2 block £1000
2.7 crank & head £1000 (still trying to source these)
8.5:1 pistons £1000
Carillo rods £1000
clutch £350
intercooler £300
72lbs injectors £250
assembly and installation with new water pump, belts, rollers etc £2000
Two days rolling road setup £1000
new white expansion tank £35 []
This doesn't include the TiAL wastegate and electronic boost controller I already have and it also doesn't have a provison for the intake. I need to decide on MAF or MAP and which one, my original AFM is leaking anyway.
Power goal should be in the mid 400s at a sensible boost level
Now where is that Chevy engine again
You have mail.ORIGINAL: Diver944
Other 2.5 tuning claims up to 190bhp (EMC built race spec engines), but they are considered not to be massively tunable.
As it happens I know of a 944 Turbo engine complete with loom, ECUs, clutch, intercooler, wastegate and everything else that was built by a specialist (Strasse) for the Porsche race series that's for sale, which would be as "drop in" as anything could be in a Lux. That should make 290-300bhp as sold.
In terms of bracing I don't believe you need any. I don't think the Turbo shell is strengthened compared with the oval dash Lux at least. There is at least one turbo engined lux on here or at least I believe the peppermint green specimen started out as a Lux. You might want something a bit better brakes-wise, however.
morris944s2john
Peter Empson
A S2 or a 968 unit, as a standard engine, will the fitting be straight forward ?
Who are really good 944 specialists who can do the work over a 24/48 hr period rather than fitting it around other jobs and three months later my car is sitting there without an engine ?
I confess I'm a bit confised by your first comment as I was able to offer you a turbo unit standard apart from the wastegate (and the standard one is literally rubbish) and having been rebuilt with probable balancing and blueprinting (hardly a bad thing in most eyes I'd have thought when the other option is a 6 figure mileage and not having been opened for 20 years in all likelihood), and with everything you'd need apart from the power steering pump which you already have, and with the bonus of no air-con which you don't need to remove. Are you looking to get the transmission as well?.
You really should look at buying a complete donor car I think, there are rusty S2s and Turbos around that just need to be broken.
ORIGINAL: Fen
It's currently in my car, but I want it out so there's more room for something American with a few more cylinders []. I'll drop you a mail now so I can give you some more details off-line.
There must be a more suitable home just waiting for this engine surely.
Like a 968 maybe, [][].
Tam Lin
ORIGINAL: ocallen
OK I've been through this process with an 924S (not dissimilar mechanically to a 944 lux) and a 944 S2 donor vehicle. Whilst on paper it would be just about possible to swap all the parts, say, in 5 working days, if you're serious about this, then you'd see this is not advisable, as you don't want to fit components which you will soon need to take out again. Thus, on the new-to-you engine, you'll want to fit new belts & water pump, and have the top off to check the chain and cam sprockets. You'll want to see the amount of life the clutch has left. Any of these components, if worn, will need to be ordered & replaced, thus blowing the chance of completing the swap on a tight schedule.
And nothing, ever, goes 100% right first time. It's a modified 944 variation on Murphy's law.
Peter Empson
If you find someone thats done it, give them the S2 engine in advance so they can prep it then I think you should safely be able to get it turned around in a couple of weeks. Having a donor car is a really great idea and will substantialy speed things up, you need the exhaust and gearbox anyway so you may as well get an accident damaged one as it'll probably work out cheaper in the long run.
Dave at JZ did my swap and he did a wonderful job, Ollie at RPM has also done one, so these would be the people to talk to about timescales and costings (RPM have a much cheaper labour rate and I'm sure will do an exceptional job too).
JZ warned me off a turbo lump for the transplant as they felt it would be more complex and therefore time consuming, but since I'd already set my heart on a 3L engine (and the 968 ones were going for £2k+ at the time) I wasn't looking that seriously at them anyway. I can't really see that it would have involved much more labour to go with the Turbo engine, so at the end of the day I suppose it depends upon what you want from the car and how you're going to use it.
Tam Lin
ORIGINAL: Peter Empson
Dave at JZ did my swap and he did a wonderful job, Ollie at RPM has also done one, so these would be the people to talk to about timescales and costings (RPM have a much cheaper labour rate and I'm sure will do an exceptional job too.
BTW, who did you get to fit the supercharger? Just so that I know, when I get bored with 190bhp/ton...
ORIGINAL: pauly
ORIGINAL: Fen
[] To be honest I don't really mind where it ends up. Nor do I mind if the OP doesn't think it's right for him, but I'm confused by the logic for ruling it out as it sounds pretty close to his ideal to me.
