ESS Rear Box - Views pls
- Thread starter PRJ
ORIGINAL: burrow01
So explain the engineering reason for all of those aerials then......[]
PRJ
Fen - that kind of looks like what's welded onto my existing back box, but it just doesn't look right on mine, probably because it's a smaller diameter. Think you could have a square pipe on yours and still get away with it [
This causes some interesting effects, which we have ruminated on previously. Principally, as the gasses exit the silencer, instead of maintaining velocity within a pipe they loose velocity by exiting into a larger space. This can increase the potential for exhaust flames [
It looks the nuts though, and is, in comparison to most options, a cheap rear box.
PRJ
ORIGINAL: John Sims
This can increase the potential for exhaust flames [] and makes a rumblier sound.
Oh no, what a nightmare [
Think I can live with a dirty bottom if those are the potential plus points
j16jrf
It is an exact replacement of what comes on the car standard only in stainless steel. Gives a lovely deep note but very quiet still on tick over inly when revs get high can you hear the SLIGHT difference.
I like the fact that it keeps the original look but is nice and shiny when driving behind the car
Diver944
Another visible clue is the cat itself. The cat has rounded ends as it tapers down to the exhaust pipe and more heat shields. A non-cat car has square ends where the exhaust pipe goes into it.
