PHB1969
Thank youmj2k said:PHB1969 said:Thank you - could you suggest suitable trim tools please - appreciate any links etc as considering and want to make sure I have the right tools to do the job. Thank youmj2k said:Mine is a GTS also, no trim removal required, there is enough flex / gap to push the wire in with a trim tool / credit card. The a pillars are solid with alcantara covering, so there is no bulge at all visible.
Cable goes right down to the windscreen before tucked down the side of the dash & routes back towards the door & then under the rubber.
Nothing visible at all cable wise, and really easy to do.
The tool I used came with the Blackvue camera, however it looks like the 3rd from the left on these tools:
https://www.amazon.co.uk/ELZO-Removal-Center-Console-Installation/dp/B0888C1B5J/ref=sr_1_7?dchild=1&keywords=dash+trim+tool&qid=1598717584&sr=8-7
It really is much more simple than you are probably thinking it will be. Start at the top of the windscreen, leaving enough 'spare' to allow you to fix the camera & then can be tucked into the headlining, the cable will just slide up there really easily. Then between the A pillar and windscreen to the bottom corner.
Here is a link to another install, this is what I used as my inspiration but with the camera installed passenger side behind the mirror & cannot see it when driving. https://www.caymanoc.com/forums/topic/562-dash-cam-fitted-to-981/
