Gearbox rebuild or S/H?
- Thread starter dann944
Copperman05
Ok looks like the time has for a new clutch to be fitted to my S2 (@93,000miles), and, as the box whines considerably and I have been having issues with changing gear (it wouldnt go into 3rd from 4th) and now it wont change into any gear whilst in motion, I am thinking that it would be a good idea to either get the box rebuilt or put a s/h unit in at the same time as getting the clutch done.
What are peoples thoughts on this? What are costs of a rebuild? Are there different types? (full rebuild, or just bearings, syncros etc). The advantge of this over a s/h unit would be you know what you are getting, and should last another 100,000 or so? Someone had suggested an s/h LSD unit as they apparently dont whine as much or have too many problems...is this true?
Whatever I decide, looks like its going to be expensive.[&:]
Any help, as always, is appreciated.
Edd
Neil Haughey
Copperman05
By shifter do you mean the gear linkage that sits on top of the box? initially I thought this may have been the problem but I had a new short shift linkage fitted last year by RPM and the problem remains. Initially I thought it was a gearbox mechanism issue, as it only appeared to not go into 3rd gear when the car (wheels) are in motion, at a stand still I can select the gears, when moving I can not. My indie says it could also be the clutch and this would be the first thing to look at, I agree, but my fear is that I get the clutch done and miss out on the opportunity to sort out the box, after which the gearshift issue may remain. EddORIGINAL: Neil Haughey I would get under the car first and check that your problem is not shifter related. On mine I found I was lucky with how the car was sat and from the shifter on the top of the gearbox I could select pretty much every forward gear. I had a bit of an issue with 3rd and 4th when my shift mechanism was worn.
JamesO
Copperman05
Neil Haughey
sawood12
944 man
Based on past, old experience of their idea of 'reconditioning' steering racks: Id steer clear myself...ORIGINAL: Diver944 I have no experience of their workshop but [link=http://www.porscheshop.co.uk]www.porscheshop.co.uk[/link] list reconditioned gearboxes for S2 at £645 on an exchange basis [link=http://www.porscheshop.co.uk/acatalog/mechrebuildservices.pdf]http://www.porscheshop.co.uk/acatalog/mechrebuildservices.pdf[/link]
JamesO
barrysmith
Copperman05
True, however it does whine quite a bit, and I'm not sure if the gearbox oil had ever been changed until last year when I got the car (its not listed in the service book). My indie just serviced it again and asked what oil had been put in it last year as it smelt a bit burnt. He put some 75W90 synthetic gear oil in and the clutch went on the way home today, bummer.. If not getting the gearbox done at the same time isnt going to be a big saver then perhaps it is best to just go for the clutch change and see what happens. Or perhaps my indie (was RPM but just used Porshworx as I moved to London) could take a look at the box whilst he's doing the clutch and let me know. I guess this is where having an indie you trust has its advantages as I'm not sure he wont just tell me I need a re-build anyway... Thanks for the help so far EddORIGINAL: sawood12 I'd be very surprised if your gearbox needs a rebuild at such low mileage. S2 gearboxes are strong gearboxes, as are all 944 gearboxes, so unless it has seen some abuse in its time it should have plenty of mileage left. I'd be inclined to do as others have suggested- wait and see what it's like once you've replaced the clutch. And if it is OK then you can spend the money you'd mentally earmarked for a rebuild on an LSD[]
Copperman05
I am leaning towards this.. I can select the gears when the engine is running, just not when the car is moving, gearbox is turning. When stationary, I can select any gear. EddORIGINAL: barrysmith If you can select all gears , when the engine is off. It must be the clutch that's not disengaging the Torque / prop shaft. I would replace clutch, flush out the GB and replace with a good oil. should the box be duff which I don't think it will be, it not hard to remove and replace , you never know this correction may save you a lot of money.
sawood12
Neil Haughey
Tam Lin
You're a cruel, cruel man. You're supposed to let the pit crew finish their bit before driving back out on track, not make them hang on for dear life.ORIGINAL: Neil Haughey .. a race car, man the whining and rattling from the back end is shocking,.
Copperman05
