GTS ordered
- Thread starter JaseGT4
JaseGTS said:and some photos of fitting:
[attachImg]https://www.porscheclubgb.com/forum/download.axd?file=0;1103905&where=message&f=IMG_3925.JPG[/attachImg]
Jase those bottom grills look like they will be sat on the paintwork? If so this will cause marring and damage overtime.
Neil
JaseGTS said:Herei si the invoice details:
Porsche 718 Boxster / Cayman GTS - Front Grille Set - Black Finish Contains ZPR70518 Porsche 718 Boxster / Cayman GTS - Outer Grille Set ZPR70618 Porsche 718 Boxster / Cayman GTS - Lower Grille Dimensions 89cm x 21cm x 10cm Weight 1.85kgZPR70718B
many thanks Jase
Ryan9729 said:JaseGTS said:and some photos of fitting:
I think the blue tape makes it look worse, they sit on the black plastic beneath. Already pulled out leaves from the intakes and the car has only done 50 miles.
JaseGTS said:I think the blue tape makes it look worse, they sit on the black plastic beneath. Already pulled out leaves from the intakes and the car has only done 50 miles.
That's good to know, I'm still undecided which ones to get, Zunsport or those from across the pond from RGS.
Ryan9729 said:JaseGTS said:I think the blue tape makes it look worse, they sit on the black plastic beneath. Already pulled out leaves from the intakes and the car has only done 50 miles.
I've not used or seen the others but the Zunsport ones with the discount are fantastic. It feels a bitter pill to swallow to pay out on them but when you actually fit and feel the quality you will be glad. Just don't forget to mask up the bottom ones.
[attachment=IMG_3922.JPG]
1. It wasn’t a requirement for my insurance
2. If I turned it on it only reduced my insurance by £20 a year. 3. The subscription is about £230 a year so not worth it for a £20 a year discount.
I feel however, it may be a requirement on my next one due to its value. Who’s your insurance with?
Dan.
Windy_Miller
Guest of the Club
Just drive her
A special innovation to reduce exhaust emissions and fuel consumption is the adaptive cylinder control. At engine speeds of between 1,600 and 3,000 rpm and a load request of up to a maximum torque of 100 Nm, it temporarily interrupts the injection process of one of the two engine banks, and the six-cylinder engine temporarily operates in three-cylinder mode. At constant load, the cylinder bank is changed every 20 seconds to ensure a uniform load and flow through the catalytic converters. With the exception of a slightly different sound profile, this switching back and forth goes unnoticed by the driver. The effect, however, is palpable: the adaptive cylinder control can reduce the CO₂ emissions by around 11 grams per kilometre. It can be deactivated together with the start/stop function, which is featured for the first time in the 718 Cayman GT4 and 718 Spyder.
Jeff
