Have taken the 924s plunge!
- Thread starter C2dweller
I've been to look at an OK example with excellent history (91k mostly by one owner) - can I ask for some advice as to some of the problems I know about? (I've guessed at what I think this is going to cost to put right and put it in brackets - am I correct?)
After seeing the car I spoke with the previous keeper, so I know everything there is to know now!
> High water consumption - current keeper has replaced a hose but I'm unsure problem is fixed <HIGH>
> Along the sills there is a bit of rust along the seam and one patch of nasty stuff near the rear of the drivers side <HIGH>
> Heater is permanently on hot <HARD / £££>
> Exhaust rattles a little and has been welded <MED> query engine mounts?
> Recently car has had moisture inside <MED>
> Rear screen partially works <MED - but will probably not fix
> Brake pipes appeared on advisory <LOW /MED>
> OE radio is bust <LOW>
> Passenger window doesn't go up from drivers side <LOW / EASY FIX?>
> Front struts were an advisory <MED>
> Doesn't have great road holding - but this is comparing against my other P-car... hope this doesn't cause an argument [
The first one is the biggy and I don't want to buy something with a failing head gasket - is this common? When I asked about jobs done by current keeper - he pointed out a new hose he had fitted on the front part of the engine. I only put 2 and 2 together when I spoke with the previous keeper (PK) later on. PK did say that there isn't any oil contamination to speak of.
The second doesn't seem too bad to me. Inside the arches it all looks amazingly clean.
I won't list the good stuff, but there is a lot and thats why I made an offer.
The guy is thinking it over (which seems v.high when all these faults are considered!) - but I do like the cars orginality.
Any help gratefully received. Thanks, Lee
CarreraRSR
pixie*porsche
CarreraRSR
vitesse
Hi Gulp - cheers for MOT heads-up. Previous keeper mentioned the fogged dials during winter of 2009. Also mentioned unusual amount of condense on the front / rear windows. As the car has been garaged for past 6 months, all seemed fine to me. Hi A9XXC - I thought the belts were 5 years. Oh dear. Seat wear is very minor - in fact the seats look new, bolster aside. Cracked dash is also minor. Cheers for comments.ORIGINAL: RSGulp Lee, any MOT equipped garage can conduct a 'sniff test' with an exhaust gas analyzer to see whether the coolant contains combustion gases which would confirm a bad head gasket. Why do you think the car has moisture inside? Damp carpets? Where?
vincematthews
