Headlights
- Thread starter juliany27
pwafer
Anyway, just to confirm... the dip is a H7, the main is a H9. The side lamps are NOT 5W5 standard lamps however
The side lamps are the same type I had in my Audi S4, offset baynoet type that I don't think you can replace for blue/led types.
P.
ORIGINAL: pwafer
They are a 5W halogen bulb - and they are quite expensive at about £5 or £6 each [
On the earlier cars this is used with the Litronic lights only, and the "standard" lights have the more normal 5w tungsten sidelight bulbs.
baptistsan
ORIGINAL: baptistsan
Just ordered a set of Philips bulbs to replace whatever rubbish is currently in the headlight unit. Changing the bulbs over sounds a real pia though. Any tips or DO NOT do's before I embark on this mission?
Mate,
I just went to halfords and bought xenon gas 4 for mine , same bulbs as was quoted before on this thread. Me and a halfords guy fitted them but it was a PITA. Anyway it's done now and they do look a lot brighter I just tried in my underground garage . Make sure you do all 4 bulbs, dipped and main beam. You buy one get one free so with fitting it was 47.99.
Jamie
ORIGINAL: pwafer
Just for information, the FRONT SIDE LIGHT bulbs are available in Philips Ultra Blue from www.powerbulbs.co.uk
The lamp is a H6W... not cheap at £15 a pair !
P.
Nice but after the agro of getting those lights back in I dont wanna take them out for a long time .
ORIGINAL: pwafer
hmmm...!
I found it a doddle in the dark with a maglite in me gob for light.
Only fiddly bit was making sure the lock back in place, but not a problem.
What year is your car... wonder if there are different mechanisms through the years ?
P.
2000 model 996. One went in no trouble but the other was a pain, there must be a technique to it.
You should have a small box spanner in the tool kit.
chriscoates81
chriscoates81
devans
chriscoates81
Porsche also did a retrofit Litronic package without a levelling system, although there was a 'control' box in the kit which connected to the light unit.
Matthew is correct that you can fit Boxster lights to a 996 and maintan the manual levelling system on a halogen light by transferring the motors, but as I said, the levelling system for Litronics is different.
